Manjesh Gowda
Joined Oct 19, 2020
89
I am newbie in programming the microcontroller. I would like to test the micro by blinking the LED in a pin. The micro is SAMR35J18B and I am using ATMEL ICE programmer and ATMEL studio software for the programming. I am able to detect the micro in the software but I could not find proper program to blink the led. I tried few and did not work out. The pin PB02 is connected to LED through a transistor. I will attach the code which i used. Could someone tell me what is wrong with the program or please attach a link for a basic LED blink program. Thank you.
C:
#include "sam.h"
int main(void)
    unsigned int i;
    /* Initialize the SAM system */
    SystemInit();
    REG_PORT_DIR0 |= 1<<2;
    /* Replace with your application code */
    while (1)
        REG_PORT_OUTTGL0 = PORT_PB02;
        re
        for (i=0;i<100000;i++)
Moderator edit: code tags added like this [code]… your code …[/code]
Pushkar1
Joined Apr 5, 2021
416
#include "sam.h"
int main(void)
unsigned int i;
SystemInit();
while (1)
re
Have you compiled code, do you get an error after compiling the code?
Please use the code tag to post to code
Manjesh Gowda
Joined Oct 19, 2020
89
Yes I have compiled it and I did not get any error. I was able to flash the code as well. The problem is i am not getting enough voltage at the pin PB02 to turn on the gate of the transistor inorder to turn on the led.
BobTPH
Joined Jun 5, 2013
11,630
I don’t know the micro or the compiler you are using, but I certainly don't see anything in your program that would flash an LED.
Bob
BobTPH
Joined Jun 5, 2013
11,630
Here us what an LED blink orogram looks loke on a pic micro. Your program should look similar in structure, though the names of things will be different.
Code:
void blink()
    // Set A0 as an output
    TRISAbits.TRISA0 = 0;
    while(1)
        // turn the LED on
        LATAbits.LATA0 = 1;
        // wait 1/2 a second
        __delay_ms(500);
        // turn the LED off
        LATAbits.LATA0 = 0;
        // wait again
        __delay_ms(500);
Bob
