Problems with PAD size for SMA connector. Data sheet available
Omer Ahmed 3
Joined Apr 19, 2019
Hey guys so im nearly done designing of my project and the final steps is to put in pads for the SMA connector.
I cant seem to work out the pad sizes from the below data sheets.
Ive searched online for more information and couldn't find anything so i assume there`s something im not seeing in the below data sheets.
at the moment im assuming the pad width is to be 0.42 mm as shown in drawing sheet, is this correct ? and also what would the length be?
Thanks in advance folks !
jpanhalt
Joined Jan 18, 2008
11,087
Presumably, you are using a program to draw your schematic and PCB. What program are you using?
If you have access to the free version of EAGLE files, look in library "con-coax > SMA" and you will find something like this (they are fairly standard):
If you want to draw yourself, find a different datasheet that shows the dimensions that you need. Remember they are usually designed for double-sided boards; although, you can use just the top pads for a single sided board.
Picbuster
Joined Dec 2, 2013
1,062
hi,
look at http://suddendocs.samtec.com/catalog_english/sma.pdf
Might help I hope.
Picbuster
