Problem with Transistor
Cardosofelinto
Joined Dec 9, 2019
Hello, i'm a beginner in eletrônics and i'm having a few problems with a basic schematics, i'm trying to connect a transistor, i'm trying to connect it to my arduino but the led won't power up in the simulator, but if i connect it on the protoboard it goes just fine ... I don't know what is wrong. the sourcers in the schematics are of 5 and 10 VWhatsApp Image 2019-12-09 at 09.50.54.jpeg
ericgibbs
Joined Jan 29, 2010
21,629
hi C,
Welcome to AAC.
Try connecting the LED and the 1K in the transistor collector, connect the emitter to 0V.
Let us know how it goes.
E
Audioguru again
Joined Oct 21, 2019
6,826
You did not say the specified forward voltage or color of the LED. A red one is about 2V and a white, blue or modern bright green one is about 3.2V. Since your transistor is an emitter-follower, not as a common-emitter switch then the 4.7k base resistor is not needed.
With 5V into the 4.7k resistor then the base voltage will be a little less than 5V, maybe 4.8V. Then if a 3.2V LED is used, it and the 1k resistor get 4.8V - 0.7v= 4.1V and the current in the LED will be only (4.1V - 3.2V)/1k= 0.9mA which will be fairly dim.
danadak
Joined Mar 10, 2018
4,057
You can drive an LED in the emitetr, although that is not the best way to do so,
as Eric points out.
Here is a sim driving in emitter. 3 1N4148s were used to sim a 2V LED. As you can see
LED current is not very good.
Regards, Dana.
dl324
Joined Mar 30, 2015
18,491
Are you certain you're breadboarding the circuit as shown in the schematic? What is the voltage being applied to the base resistor.
For the way you've drawn the circuit, you're trying to switch the LED high side. For that, you'd use a PNP or P channel MOSFET. We use NPN transistors to drive loads low side.
