Large 7-Segment, SN74HC595N and BC327 Transistor Problem
sortyourstash
Joined Oct 2, 2024
I am trying to run a large 7 segment display.
My setup is currently a SN74HC595N connected to BC327 transistors. And should supply 8V to the individual segments. I have a display with a common cathode.
Somehow I have planned something wrong and don't understand what my problem is. Below is my diagram, to keep it simple I have only drawn one LED.
Ian0
Joined Aug 7, 2020
13,298
If you are using a PNP common emitter driver, then the emitter must be common to the rest of the positive supply.
It is much more usual to use an NPN transistor so then all the emitters are at 0V.
You have no current limiting resistor for the LED.
