MisterBill2
- Joined Jan 23, 2018
- 28,272
Often that Vcc/2 voltage is from a simple voltage divider and capacitor, no regulation needed because the load is constant. That reduces part count and eliminates any regulator noise addition.
Your Jfet is too sensitive and attenuates everything.@Audioguru again
I am using a BF862 with a Vgsoff of -0.8V, in the simulation I had entered it in the fet properties. Truth is, I couldn't perceive the volume change by ear, but I did hear some occasional crackling, but the circuit is unstable and sensitive to movement on the breadboard, so I thought that might be the cause.
@MisterBill2
Do you mean in AGC feedback? How should I implement it?
