Problem when firing a TRIAC at zero-crossing
Muhammad Irfan 6
Joined Dec 5, 2017
6
Schematic.jpg Case 1.jpg Case 2.jpg Hey guys im working on a BTA41-800 triac . i just want to turn on my triac when 2nd zero-cross imean my load is a power transformer so i dont want my transformer turn on at peak value of AC 220V input. i just want my transformer turn on through Triac at zero-level crossing to reduce the inrush current.
Okey my problem is that im detecting the zero-crossing using op-amp and X-OR gate.
Case 1 : In start up my circuit will work fine when input (12VPP AC ) to op-amp starts from negative cycle to positive .
Case 2 : In start up if the (12VPP AC ) waveform starts from positive imean from peak at that time my circuit will not work fine. i will generate an extra high (+5v) signal at the output of x-OR gate which is what idont need.
my requirement is that i want to make a logic which can skip the first output pulse of X-OR and take the second pulse (2nd zero-crossing) as a final output.
Regards: Engr. Irfan
Motanache
Joined Mar 2, 2015
652
That's why I use MOC3041 and you have galvanic isolation with the control circuit.
Until now I only used this optoriac alone. Give it the command before passing through 0V, but it only starts when the sinusoid passes through 0V.
Motanache
Joined Mar 2, 2015
652
- I did not understand why is usefull to switch at a second pass through 0V
- I do not think it's a problem when the triac starts at maximum value of sinusoid.
(E.g. the triac is firing at the phase 90 degrees) because the primary of the transformer has a fairly large impedance and will not allow the current to grow very fast through it.
If you want what you said solutions are:
- microcontroller and remove the rest of the pieces (it can make the detection of 0V cross and counting second one)
- or the schematic presented by you plus a counter or bistable
Motanache
Joined Mar 2, 2015
652
If we consider the impedance of the primary transformer L and the resistance of the primary coil R, then your time base(tau) does not depend on the voltage.
If you fire triac at a 90 degree angle you might even have a lower current then normal
(not the same thing happens to the SMPS that charge a imput capacitor. There are big currents)
Muhammad Irfan 6
Joined Dec 5, 2017
6
Hey guy i hope you are all fine .. im very thanks for your help .
Basically im using a power transformer 50A transformer and i want to make a soft starter. so i make a decision to try a different and reliable technique, which is relay base technique .
Normally my transformer primary coil charges up though a current limiting resistor and after one or 2 seconds my relay makes the contract for inputting the full power to transformer. I hope by using this idea my transformer will not takes high inrush current. Now i want to calculate that current liming resistor.
38,513
That depends upon the transformer load.
With a low impedance load, such as a rectifier capacitor filter, firing at the peak of the sinewave will generate a much larger inrush current than firing at the zero crossing.
anishkgt
Joined Mar 21, 2017
549
Just sharing my experience with one such project. i used an arduino to accomplish this. H11AA1 used a zero cross detector, meaning it would give a pulse for every zero cross detected. Then use arduino's interrupt to detect it.
Hope this helps.
