I am currently trying to get SPI data transfer between the MPC5744p and a Raspberry Pi 4 to work.
I'm using the SPIdev python toolkit to send the value 26 over to the MPC, using the attached SPItest.py script.
To receive this, i've modified the code of the SPI_MPC5744P example to only expect data arriving on the slave DSPI2.
When testing this my connections were as follows:
Raspberry Pi NXP
SCLK → DSPI_2 CLK (PA0 - J5_1)
MOSI → DSPI_2_SIN (PA2 - J5_5)
The code on the MPC5744P was intended to send a message to UART when SPI transfer has happened. However, when using the script on the Raspberry Pi, I could not get this message to show up.
I'm currently stuck as I can't seem to find out what I'm forgetting?
At first I thought that i also needed to connect the Slave Select pin, but the reference manual says that you shouldn't tie this to ground?
The code-archive for the NXP MPC5744p (I used the S32 Design Studio IDE) and the python script for the Raspberry Pi are in the attachment.
Thank you for your time.
Raspberry Pi NXP
