Probem in opamp circuit
aragon1971
Joined Apr 7, 2008
160
Hi
i establish a circuit in laab
an opam amplifier with symmetric voltage . In input of the circuit theere a small signal form a generator
When i trying to meausre the output voltage i see that one suplly voltage the value decrease
why ?
thank
George
BobTPH
Joined Jun 5, 2013
11,675
I am going to rephrase what I think you are asking.
When you try to measure the voltage at the output pin of the opamp, the voltage of one of the power supplies drops.
Is that correct?
aragon1971
Joined Apr 7, 2008
160
hi
i want to measure the outtput voltage at pin 6
in figure show that connect the - output to + output of power supply this is the reference for all measure
Ramussons
Joined May 3, 2013
1,572
Can you please draw the connections when measuring the pin 6 output ?
Are you measuring between pin 6 and the Ground ?
I think you are, by mistake, measuring voltage between pin 6 and power supply + and power supply - .
Or how will you know that power supply voltage Drops?
aragon1971
Joined Apr 7, 2008
160
the ground for my circuit is the common connection of - and + this ground IS WRONG ?
28,525
It is correct, and often called the "common" , which is more correct than calling it "Ground". The reason I say that is because ground is also a connection to the common side of everything else. Common is the reference point within a circuit or system, and so it is only a part of that system until it is connected to something else. That can be a great benefit for analysis because it is not connected to unknown quantities.
aragon1971
Joined Apr 7, 2008
160
I use a signal generator in input pin 2 and an oscilloscope in pin 6 and the power supply for symmetric dc voltage where is the problem ?
28,525
Both the signal generator and the oscilloscope also have the second connection, which would be to the common. Every voltage measurement is between two points. Mostly that second point is the "common" of the circuit. But not always, THAT can lead to confusion.
It is a lot like measuring distance, which is always between two points.
BobTPH
Joined Jun 5, 2013
11,675
Tell us EXACTLY how everything is connected, including ground on your two power supplies and the ground clip in your oscilloscope probe. I suspect you are shorting one of the power supplies with your oscilloscope ground.
Edit: also the signal generator ground.
aragon1971
Joined Apr 7, 2008
160
In the common ground of circuit ( define by the connection + and - in power supply ) connected all the other ground from the generator and the oscilloscope
28,525
I see a language and meanings problem here, as well as a desperate searching for what the problem actually is. That is to say that there is something important that we do not know just yet, And I am not sure what that missing bit is.
The first circuit in post #1 is not actual, the second circuit in post #1 includes neither power supply connections nor any hint as to te amplitudes of the signals, nor DC offsets.
ALL OF THE VOLTAGE MEASUREMENTS ARE NEEDED FOR A MEANINGFUL EVALUATION.
aragon1971
Joined Apr 7, 2008
160
a complete circuit
Ramussons
Joined May 3, 2013
1,572
This is what I asked in Post #8
This drawing is for Output Signal Measurement. It is correct.
What is the Drawing when measuring the Supply Voltage?
Hi George. Your power supplies need to be "floating" to be connected in series. If their negative terminal is connected to Chassis, one of them may be shorted (the bottom one). Your scope definitely has ground clip connected to Chassis, so when you connect it between your power supplies (Ground point of your schematic) it also may interfere with the operation of the bottom power supply
