feeding antenna with TEM modes logic probem
yef smith
Joined Aug 2, 2020
1,486
Hello there are antennas like stripline fed or coaxial fed antennas in which the input mode is TEM.
but then i thought ,how can TEM be the input of an antenna if TEM in a NON propogating mode?
Thanks.
but then i thought ,how can TEM be the input of an antenna if TEM in a NON propagating mode?
Thanks.
It is propagating into space as radiation.
https://interferencetechnology.com/antenna-fundamentals/
Figure 3. (a) Electric field E and (b) magnetic field H and TEM field from dipole charge and current
Figure 4. Power flow resulting in radiation.
