Pressure sensor programme using XGZP6847A001MPGPN sensor
lucky930
Joined Jan 7, 2024
21
Hello Programmers,
I'm quiet frustrated now as I'm unable to figure out how I use the XGZP6847A001MPGPN pressure sensor of range -750mmHg to 7500 mmHg using ATMEGA8 chip and ADC 1 channel (10bit adc).
I've the setup already and able to get the readings from pressure sensor to display. But dont know how can I limit the pressure within specified range suppose 0mmhg to -130mmhg.
Please help me with the formula in C embededd to use.
Jerry-Hat-Trick
Joined Aug 31, 2022
838
Without checking the details of the pressure sensor you are using I’ll assume that-750mmHg reads zero and 7500mmHg reads 1024. If you are only looking for measurements between zero and minus 130mmHg surely you are using the wrong sensor? 130/(7500+750)x1024 = 16 giving you just 4 bits of resolution over that range?
Ignoring that, for the full range of 8250mmHg you have 1024 possible values so multiply the ADC value by 8250/1024 and subtract 750 to get to mmHg
lucky930
Joined Jan 7, 2024
21
https://www.google.com/url?sa=t&sou...UQFnoECBcQAQ&usg=AOvVaw1nWSait44pwdgBWnbFlmWZ
Here is the pdf link.
Can you check an help.
Jerry-Hat-Trick
Joined Aug 31, 2022
838
Thanks, but that tells me nothing really new. It looks like you are using the last part number in the list on page 5 with range -100 to 1000 kPa which is the same as -750 to 7500 mmHg as you stated. If you want to read from 0 to -130 mmHg which is the same as 0 to -17.33 kPa you should use sensor XGZP6847A020KPGN33 which has a range from -20 to 0 kPa which is -150 to 0 mmHg. In this case the arithmetic would be times 150/1024 minus 150 mmHg
lucky930
Joined Jan 7, 2024
21
Well actuall thing is using 100kpa sensor which ranges from -100kpa to 100kpa, I can get it to work within range of 0 to -125mmHg. but not the sensor with -750 to 7500 mmhg range sensor.
