Help to identify pressure sensor
kzsolt87
Joined Jul 13, 2023
23
I pulled this sensor from a tire air-compressor, which I believe measures the pressure while operating. I couldn't find any datasheet, so was wondering if you can help identifying or at least give an idea how would it operate. It would be great if I can build some circuits around it for the fun of it!
Irving
Joined Jan 30, 2016
5,195
It's a 7bar (700kPa) absolute pressure sensor manufactured by SIMST in China
5v 1mA excitation, output is 100mV -30/+50mV at full scale with 0Pa offset +/-50mV, so calibration required. Open to atmosphere should give about 14mV assuming vacuum is 0mV, and unit is typical for FS range.
Datasheet (such as it is) attached. Have fun.
kzsolt87
Joined Jul 13, 2023
23
Thank you @Irving !
