Pressure sensor and amplifier difficulties
Mark Flint
Joined Jun 11, 2017
145
hi M,
Ref AD623 current input limiters, they should also be configured as noise suppressors.
E
The circuit gets bigger all the time, lol. I'm away from the bench for a week but will get this tested again soon enough. I think I'll chance it without the noise suppressor additions but I know where to go if I don't get a usable signal. Thanks again Eric.
ericgibbs
Joined Jan 29, 2010
21,442
hi Mark,
If you don't want to fit all the suppressor components, at least add a 4k7 resistor in series with the AD623 in+ and in- inputs , this should limit any highish input fault currents.
E
Mark Flint
Joined Jun 11, 2017
145
hi Mark,
E
Hi Eric,
I have added the 4k7 resistors and I am powering both the pressure sensor and the amp with the same 11.11v supply. I am about to test again with a new amp chip. So far I have fried 3 :-(
I am going to add the recommended decoupling caps (0.1uF and 10uF) on the Vs line - I think they are necessary.
Regarding output buffering... from the datasheet (see clip) it requires a 10k load. Do you think I should be concerned about the load resistance offered by an Arduino analog pin?
ericgibbs
Joined Jan 29, 2010
21,442
hi Mark,
The input resistance of a MCU input is pin is very high, so no loading problems.
I would add a 10k from the AD623 output to 0v, it will help the pull down closer to 0v.
Decoupling is essential on the power rails.
How did you zap 3 OPA's .:rolleyes:
E
Mark Flint
Joined Jun 11, 2017
145
hi Mark,
Thank you - I'll add the resistor.
E
Just careless I guess. I'm learning a lot from this project.
Cheers, Mark
Mark Flint
Joined Jun 11, 2017
145
An additional point- 100pf is wayyyyyy too small- see the data sheet.
Thanks - yes that was a typo, I meant 100uF... which is actually too high. I'm now using 0.1uF (and 10uF) as per the datasheet. Sadly my Arduino has expired and I'm waiting for new stock before I can continue.
Mark Flint
Joined Jun 11, 2017
145
Well, finally got this all working. I've only got a 1k resistor to set amplification which I'll swap for a 10k pot. But apart from that I'm happy with the solution. Thanks for all the help.
Here's my final schematic for anyone interested.
