I'm using gas pressure sensor MPX2050GP with instrument amp AD623.
This is the documentation I'm referencing:
Sensor datasheet
https://www.nxp.com/files-static/sensors/doc/data_sheet/MPX2050.pdf
Amp (datasheet attached)
https://components101.com/ics/ad623-instrumentation-amplifier-pinout-datasheet
When I apply 12.32v to the sensor I read 4.74v from pin 2, and 4.08v from pin 4. This is at ambient pressure. This is the first thing that seems a bit mysterious to me - I thought the + and - outputs would be much lower.
The outputs go to pins 3 and 2 respectively on the AD623. The output from pin 6 reads about 1100mV at ambient pressure. When I apply 20 psi this output voltage increased by 35-40mV - which is what the sensor differential output is specifies as.
I think there's a possibility I have damaged the amp chip. Trouble is I'm not sure that the sensor is outputting correctly either.
Any tips would be appreciated.
EDIT: rough schematic now attached.
Sensor datasheet
