Pressure passive sensor connection to 0-5 input logger
Vspec
Joined Mar 22, 2019
6
Dear Sir´s I have the following situation:
I need to connect a passive sensor from STS sensors model TM/N, link below
https://www.stssensors.com/Pressure...tName=NiveausondenTM_N&vId=0#NiveausondenTM_N
This sensor have an output of 0-25 mV and a power supply of 15V.
I need to connect this sensor to a logget from Inventia model MT713, link below
http://www.inventia.pl/ENG/MT-713_b...er_and_data_logger_with_GPRS_transmission.htm
This loggers can power the sensor without problem wuth 15V the issue is the signal input as the logger hava an analog input range
from 0-5V.
So my question is can I use a kind of istrumentation amplifier to be connect such sensor to this logger?
Can any one help me in the development of an electric circuit to made this connection and have a good resolution?
With best regards
David
MOD: Added d/s clips.E
pmd34
Joined Feb 22, 2014
529
Hi David,
Something like an INA326:
http://www.ti.com/lit/ds/sbos222d/sbos222d.pdf
makes a very simple option for such an application. The gain is easily to program with a minimum of components, and the data sheet is very helpful.
You may be able to find similar ones with a larger power supply range that would allow you to drive it directly from your sensor power supply however.
AnalogKid
Joined Aug 1, 2013
12,265
What power sources are available to run the interface circuit?
How accurate does the output need to be down around 0 V?
ak
sghioto
Joined Dec 31, 2017
8,750
The INA122 will work on a single supply up to 36 volts, minimum output offset is 100mv .
This can be eliminated with additional circuitry if needed.
SG
Vspec
Joined Mar 22, 2019
6
Hi David,
Thank you I think this can solve my problem.
As I can see I need to have a gain of 100.
My only issue is that I have an signal of 0-25 mV if I have an signal of 0-50 mV with a gain of 100 I will have an output of 0-5V that is wath i need
pmd34
Joined Feb 22, 2014
529
Thats no problem! See page 9 on the data sheet, it tells you how to get any gain you want!
AnalogKid
Joined Aug 1, 2013
12,265
At zero I must have 0 mV output
That could be a problem. "Rail-to-rail" devices and circuits cannot actually produce an output voltage exactly at either rail. To get an output at exactly 0 V, you generally need a circuit that can swing below 0 V at least a little bit. There are tricks to get around this for AC signals such as audio, but not for slowly-varying DC signals.
Since you are not making much output current, one solution is a small charge-pump circuit to generate a small negative voltage to power the opamps.
ak
Vspec
Joined Mar 22, 2019
6
Yes thank you. With a 0 to 25mV signal I need a gain of 200, so i will use R2=100 Ohm and R1=1 Ohm and will get the gain that i need.
I will buy this amplifien and make same test and will give feedback. Thank you for the fast and usefull help.
Regards,
David
