PRECOR IFT DRIVE
IndikaDK
Joined Mar 5, 2021
Hello friends
I have PRECOR IFT DRIVE 932i,
This IFT DRIVER BOARD have two PCB,s
lower board and upper board.
upper pcb board one of SMD transistor is missing,
if someone know about this PRECOR IFT DRIVE.
I WOULD LIKE TO KNOW MISSING SMD TRANSISTER CODE OR NUMBER.
I can upload some photos.....
pcb location number is [ Q11 ] {Q11 is missing SMD transister }
[Q10] SMD code number is [ SS ]
if someone can help about it.
thank you
Eyvind
Joined Jan 13, 2022
Hello friends
thank you
Hello friends
thank you
Hi, se attached picture.
Maybe you can help med with component U12 same circutboard?
IndikaDK
Joined Mar 5, 2021
Hi
Thank you very much for support, highly appreciated.
I can put on the your broken IC details .
Regards from Denmark
sagor
Joined Mar 10, 2019
1,055
Chip seems to be a ICE2A265, a current mode controller.
It is entirely possible the missing Q11 was never populated, the solder pads seem like they have never been used. But, if there was one there, odds are likely it would be similar to Q10, but that's just a guess. Without a schematic, no way to know for sure....
mapsama
Joined Nov 13, 2023
Hello friends
thank you
Here you go
mapsama
Joined Nov 13, 2023
Here you go
I have that board too but mine is for precor trm823 and I needed completely because there's a few times that blows a circuit and a couple of capacitor and I think I needed to replace it all the board, and a need help if anyone knows where to find it I appreciate it if you let me know
I am having issues with one my my IFT's not powering the upper PCA unit. I have checked the cable and upper PCA with a different IFT and it runs as it should. But I am unsure what part of this IFT could be damaged that would effect this. Any suggestions?
