Nope I haven’t tried that yet. What if I don’t have a different audio signal to try it out. What should I do?Have you tried connecting a different audio signal to the MAX to verify it's working?
You do not show how the amplifier is connected.
Here are a couple more problems with your preamp:
Thank you, should I put the bypass filter for the 3.3V in parallel or in series? I’ll take out the capacitor and resistor and increase to resistor load and let you know if it works.You do not show how the amplifier is connected.
I see I’ll try that, thank you.The preamp should be connected to the MAX this way.
The bypass capacitor bypasses the 3.3V. Bypass means in parallel. Try 47uF plus a 0.1uF (104) ceramic. They prevent oscillation.Thank you, should I put the bypass filter for the 3.3V in parallel or in series?
