Powering my SN74HCT00 IC
Davidzb
Joined Mar 3, 2017
Hi all,
My first post so here we go. My SN74HCT00 IC specs are VCC = 4.5 V to 5.5 V and input current of 1 µA Max
What would be the best way to regulate my 9v supply to meet these conditions? Voltage divider? Zener diodes?
Thanks in advance for any help
David
AlbertHall
Joined Jun 4, 2014
12,663
The LM78L05 will supply up to a maximum of 100mA. As long as you are drawing less than this then it will keep the voltage at a very stable 5V.
35,323
Does it have to be 74HCT00?
Use a CD4011 and it will run directly off a 9V battery.
Note that the pinout of CD4011 is not the same as 7400 NAND gate.
Davidzb
Joined Mar 3, 2017
Thanks everyone for the advice.CD4011 will be fine. Looks like adding another IC is the way to go
Much appreciated
