Powering my project, need help plz
jakethehusky
Joined Mar 24, 2016
22
I just finished my rgb controller that works with pc via an Arduino nano. I use mosfets to use the higher current, for powering the rgb ledstrip I need 12V DC and around 0,700 A. I don't have any adaptors/transformers laying around that would work out.
What would be the best place to buy one? Is there anyway around using another one and modifying it ?
jpanhalt
Joined Jan 18, 2008
11,087
What are your size limits? One option is to get a discarded PC and use its power supply. I still use one.
Another option is MPJA or Jameco/ Each has lots of inexpensive supplies
http://www.mpja.com/
http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&categoryName=category_root&subCategoryName=Power Supplies & Wall Adapters&category=45
You will need to choose between an open chassis, enclosed unit, or wall wart.
There are also numerous surplus dealers, like Electronic Goldmine, Allelectronics, and Surplus Center.
http://www.surpluscenter.com/
http://www.allelectronics.com/
http://www.goldmine-elec-products.com/
Finally, you could consider a battery charger. If you go that route, I recommend using a 12V regulator.
John
InspectorGadget
Joined Nov 5, 2010
215
Use an atx psu, or laptop psu.
Laptop PSU's are usually 16-19V. I don't think he needs that much.
An ATX PSU is often load-dependent. You might have to put a load resistor on the 5V to get the 12V to work.
Better to find a 12V brick somewhere. Any electronic catalog will have one, surplus store will have one even cheaper.
18,117
For what it's worth, the power supplies that ship with a lot of computer peripherals (hard drives, routers) are 12V and are rated to supply 1A or more. If you have an electronics recycling spot anywhere nearby, you can probably grab a few of them for free.
