Powering a spinning board?
spinnaker
Joined Oct 29, 2009
7,830
I will be building a propeller clock soon. I need to figure out how to power the pic while the board is spinning.
Easy solutions are an on board battery or super cap. The probably with these solutions is eventually they run out of power.
I want something that can keep on running pretty much forever. Some way to get power to the board from a remote location or generate it locally.
I saw one idea when they somehow threaded wires of the center of the shaft of the motor. First not sure how you would get a hollow shaft in a motor without drilling it yourself. And one end is still stationary and the other end moving.
Another though use a super cap but charge it though brushes and contacts on each spin. Seem making something like that to work reliably could be difficult.
I tried an old floppy motor once as a generator. Didn't generate much in the way of power.
Would a peizoelectric crystal work, perhaps charging a subercap?
WBahn
Joined Mar 31, 2012
33,274
Given that slip rings are used on motors for long periods of time, I would thing that would work pretty well for your application.
Another thought would be to mount a little motor/generator on the propeller shaft. After all, does it really matter if the shaft of the generator turns in fixed generator housing or a generator housing turns around a fixed shaft?
Sensacell
Joined Jun 19, 2012
3,789
You can easily build a rotary transformer from pot-core halves face to face with a small air gap.
This is the true last-forever solution.
The Mercotac slip rings work well, but don't last forever, and are rather expensive.
DickCappels
Joined Aug 21, 2008
10,661
I know an engineer who made a magnetic coupler for this purpose -as I recall it involved two halvs of a pot core. The primary was in one half and the secondary was in the other half.
There was a substantial air gap between them so there was no friction between the two. That's all I remember about it.
OBW0549
Joined Mar 2, 2015
3,565
You could use the same technique used for wireless charging of cell phones, as described here.
Two wire coils a couple of inches in diameter mounted concentric with the shaft, the transmitting coil mounted to the baseplate and the receiving coil mounted on your propellor disc, the two coils separated by about 1/4".
Forget anything piezoelectric; not powerful enough.
Reloadron
Joined Jan 15, 2015
7,962
My best guess is slip rings. I have seen some tiny sets used on brushless synchro transmitters, like a miniature version of what you would find on an automotive alternator. They could be made from some copper tubing with an insulating material. The brushes could be just some light gauge spring loaded wire.
Ron
AnalogKid
Joined Aug 1, 2013
12,284
It sounds like you want to put the PIC and LED drivers out on the propeller. Why? Also, what about the set mechanism (buttons, etc.)? Consider putting the bare minimum out on the blade. Parallel drive to 5x7 dot characters would need 8 contacts, but serial drive to shift registers would need only three.
ak
GopherT
Joined Nov 23, 2012
8,009
ak
It's a propeller clock, he only needs a 5 x 1 display.
Sensacell
Joined Jun 19, 2012
3,789
ak
You will find almost ALL well designed spinning displays put ALL the electronics in the spun section.
Imagine the contact bounce issues you would have sending a digital clock signal through a rotating contact!
The rotating joint is the weak link.
AnalogKid
Joined Aug 1, 2013
12,284
I know. I used the term 5x7 to reference a well known raster character set. But I think a 5-high display is pretty coarse, kinda the bare minimum for legibility. I have an old wand clock, one of the first, and it has a 7-high display. Fine for numbers, passable for text. 9-high would be better.
ak
