Powering a DIY active audio mixer
ttshaw1
Joined Jan 24, 2016
14
Hi, everyone. I want to make a 3.5mm audio mixer so I can input from my guitar amp and my computer to my computer speakers. I found a description of one on http://www.circuitlib.com/index.php/tutorials/product/39-how-to-build-an-audio-mixer
with a few useful schematics.
The above picture shows the overall mixer. I'm going to skip the tone control modules. I'm planning on breadboarding everything so I can add them later if I want. For now I only want input modules and the summing amplifier.
This is a picture of an input module with separate left and right channels.
And this is the summing amplifier.
I've got a few questions, mostly related to powering the op-amps. In both modules of interest, each op-amp only has one power channel shown. Should I assume that every op-amp has both +15V and -15V power lines, each grounded through a 100nF capacitor?
I'll need a +-15V power supply. Can anyone recommend something cheap? If not, I was thinking I could invert a +15V line from a standard 15V adapter with an op-amp and leave ground alone. Would that be noisy?
To split 3.5mm to left and right channels, can I just make contact at the tip and the middle section? Do I need audio ground for anything?
blocco a spirale
Joined Jun 18, 2008
1,546
U2A and U2B are in the same package so the representation is correct; each package requires +15V and -15V.
How about powering it with one of these, it looks like a good implementation and is suitable for your application:
http://www.ebay.co.uk/itm/Adjustabl...354275?hash=item235f566aa3:g:jFAAAOSw9N1VpOX1
You will also need a small 2x18V transformer to go with it, 10VA should be ok.
You must use the audio ground, it is the return path for the audio signal.
12,164
If you look at the LM833 datasheet, you will see that it is a dual part. There is no "standard" way to show a single power connection to a multi-stage component on a schematic like a dual or quad opamp. The first schematic has an error. U2B should be marked U1B, the other half of U1A on the schematic.
