Power transistor rated 70V not 12V?
JerryF13
Joined Dec 1, 2017
25
I have a faulty solenoid valve from a hydraulic levelling system in an 1988 US motorhome. I sourced KT825G BDX66 T03 transistors to repair. I’ve been having issues with this in that when the return spring is fitted the plunger doesn’t move, without the spring it does. I recently noticed that the transistor is rated at 70V, not the 12V I was expecting. Could anyone tell me how that might affect the operation and/or if that might have caused the problem I have now?
Thanks!
AlbertHall
Joined Jun 4, 2014
12,653
A 12V battery on charge is 13.2V+ so a 12V transistor would not be a good idea. The 70V is the maximum voltage which the transistor can withstand but it could be used with any voltage down to less than 1V! It is wise to use components well within their maximum ratings. They last longer that way.
I don't think the rating of the transistor is cause of the spring/plunger problem.
OBW0549
Joined Mar 2, 2015
3,565
That rating specifies the maximum voltage the transistor will withstand, not the voltage at which it must be used.
pmd34
Joined Feb 22, 2014
529
It sounds like the solenoid is not powerful enough to overcome the power of the spring. I would try and isolate the solenoid, and then see if it works if you connect 12V directly to it, if it does you are dropping too much voltage in the switching circuit (maybe use a MOSFET instead of a BJT transistor, if not you need to try and replace the solenoid or get more oomph out of it! One possibility is to take some of the turns of wire off the solenoid, but this would be a desperate step perhaps!
AnalogKid
Joined Aug 1, 2013
12,266
All other things being equal (they never truly are, but ... ), a transistor with a higher voltage rating will have a *slightly* higher saturation voltage. It should not be enough to affect the operation of your system.
What is the part number of the original transistor? If it has higher gain (maybe a Darlington?), that could cause the symptoms you are seeing.
ak
JerryF13
Joined Dec 1, 2017
25
Thanks AlbertHall, that's cleared that up for me
Thanks OBW0549
Its the same solenoid/spring combination as has been working for 30 years. But what you've said has made me think it could be a mechanical issue so thank you.
ak
Thanks ak. It's KT825G BDX66 but I am leaning towards other solutions after having read previous replies.
Yes mvas! All the help I got from this forum allowed a successful repair. Why it stopped working again I really don't know. I suspect a short somewhere, it's a tight physical layout. Thanks
sparky 1
Joined Nov 3, 2018
1,218
It looks like darlington pnp
possibly doing a manual over ride is a way to gain insight into test point location on the controller.
ian field
Joined Oct 27, 2012
6,536
Thanks!
Transient suppressor devices for automotive systems are often rated to clamp at 68V - so your transistor has a smidge of safety margin.
The solenoid also generates a back emf when the transistor switches off - the solenoid is one of the types of components that generates the transients the transistor needs protecting from.
