POWER MOSFET gate and drain
pjreijiri
Joined Aug 19, 2015
116
Hello everyone, I want to make a circuit for an H-bridge, I will be using IR2110 with IRFP4468. I will connect the HO (pin 7) and LO (pin 1) to the gate of the IRFP4468. I am using 12V for the Vcc (pin 3) and Vb (pin 6) and need to run the motor at 12V.
Will it give me problems to have the voltage at the gate of the MOSFET the same as the power supply that is applied on the drain of the same MOSFET?
38,521
Not as long as the MOSFET Vgs maximum voltage rating is not exceeded as stated in the data sheet Maximum Ratings section.
