power help relays vs mosfets
nico.paul
Joined Feb 2, 2019
hello, I want to connect an rpi 3 b+ to 2 12v solenoid locks, a camera and a speaker module and microphone module. I cant figure out what i need transistor wise though. will a 12v 4 channel relay not be enough to power both locks? im beginning to think no and should have gotten 24v. mosfet? im really lost as to when you use one vs the other and if you can use both. aux power jacks: do i connect to the relay of i have one and if i dont the mosfet?
MaxHeadRoom
Joined Jul 18, 2013
30,773
Not sure of your circuit, but there is the Omrom MY4ZN 4 pole style relay with 4 contacts.
You could also drive with Mosfets, are these switched simultaneously?
Max.
nico.paul
Joined Feb 2, 2019
the 2 12v sols are simultaneous. would i need two mosfets then? each sol will be powered by its own ac wall adapter and i think i need to get a barrel jack that i can hook to either the mosfet or the relay? im newer with electrical engineering and i can confirm its not as easy as some think. haha
MaxHeadRoom
Joined Jul 18, 2013
30,773
You should be able to power with one Mosfet, don't forget the reverse diodes across the solenoids.
Also two could be used from the same drive signal.
It helps to post a circuit and component details for definitive answers.
Max.
