Possible marking key mistake? Microprocessors
Munnsy
Joined Feb 20, 2023
I have been racking my brain trying to figure out why the marking key uses 5V in this problem to size R1 when the supply voltage is 12V for the voltage divider.
Any help would be greatly appreciated.
Munnsy
Joined Feb 20, 2023
Thank you for the reply,
My assumption would be that that the highest current supplied would be when the variable resistor is 0 ohm so R1 = V/I = 12/0.02 = 600 ohms.
This is Mark scheme for a statewide university entrance exam so having difficulty accepting the answer could be wrong
35,249
I agree with your answer.
Jony130
Joined Feb 17, 2009
5,601
The answers they give do not meet the power consumption requirement. Because I = 12V/(250Ω + 178Ω) = 28.03mA. Which is larger than 20mA.
WBahn
Joined Mar 31, 2012
33,289
At first it looked like they might have simply swapped the roles of R1 and R2 in their answers, but their problems go way beyond that.
Since the current is given by
Io = Vo/(R1+R2) <= 20 mA
You immediately get the constraint that
(R1+R2) >= Vo/Io = 12 V / 20 mA = 600 Ω
Since R2 can be 0 Ω, that means that R1 >= 600 Ω
Giving the benefit of the doubt, it's possible the answers are for an earlier version of the problem and they didn't get updated when the problem changed.
