Positive/Negative Pulses against One Pulse
ericgibbs
Joined Jan 29, 2010
21,562
How shall I reverse the polarity of the signal for C? Any simple approach?
When you say 'reverse the polarity' do you mean pulse 'B' is High going from 0V to +V and 'C' is Low going from +V to 0V..?
35,125
The monostable multivibrator chips provide both Q and Q-inverted outputs.
For 0 to -5V you will need a bipolar power supply and a level shifter circuit.
abuhafss
Joined Aug 17, 2010
318
I have ended up with this design. The output in this simulation is quite acceptable.
Pot A and Pot B are ganged together. The right op-amp is powered with dual supply and the remaining two with single supply.
Shall appreciate your valued comments/suggestions for refinement/improvement.
