PMOS NPN configuration to drive CGHV1A250F
yef smith
Joined Aug 2, 2020
1,475
Hello ,The main goal is to Bias the CGHV1A250F transistor which is represented as 3 Ohm load resistor.shown below using PMOS shown below datasheet and spice model.LTspice file is attached with the imported spice model of the PMOS.
I know the conditions for opening PMOS and NPN shown below.
Suppose my pulse is in ON state.
Given the diagram below,what is the strategy for formulating the current that will be flowing threw as a function of NPN and PMOS expressions?
So i'll know what is the role of each element an how it influences the current going into the load resistor.
Thanks.
https://pdf1.alldatasheet.com/datasheet-pdf/download/1673867/WOLFSPEED/CGHV1A250F.html
PMOS:
https://eu.mouser.com/ProductDetail/Nexperia/BC848B215?qs=me8TqzrmIYWVIx0akKpYzQ==&utm_id=6470900564&gad_source=1&gclid=CjwKCAjw3NyxBhBmEiwAyofDYdMdsOjuIRXNOO_IIm4SrIL6_HIKGgpEd1vVxYqDajgA0278Mks_wBoCL90QAvD_BwE&_gl=1*13gajfk*_ga*NDE2MTI4MDYzLjE3MTQ5MTU3NTM.*_ga_15W4STQT4T*MTcxNDkxNTc1My4xLjAuMTcxNDkxNTc1NS41OC4wLjA.
PMOS spice model:
https://www.vishay.com/doc?76129
yef smith
Joined Aug 2, 2020
1,475
Hello, Yes you arec orrect, i missed a resistorR 3 as shown below.
If we start from the NPN, what is the mathematicl epression for suchcase?
Thanks.
38,624
Exactly what bias values to you want for the transistor?
I would expect you need a voltage source, not a current-source as you circuit provides.
yef smith
Joined Aug 2, 2020
1,475
I want my CGHV1A250F transistor to be in normal operation mode, from data sheet i know that drain needs o be 28V.
However they only say the quecent current. When a small signal(RF) will enter) the current will get higher threw the drain because gm transimpedance will start working.What current shuld i use that will pass threw my load CGHV1A250F?(represented as a resistor in the circuit)
Thanks.
yef smith
Joined Aug 2, 2020
1,475
Hello crutschow, What kind of configuration do you reccomend for biasing the load CGHV1A250F transistor ?
