Hi! I have a mobile phone which has a blank screen but working. When attached to computer via usb, a tool is telling that its battery is -1% (eventhough it has a voltage of around 4.1).
Can someone pls. identify the attached component. I believe that this is a (current sensing, ultra low) resistor but its code (010) doesnt not correspond to any valid resistor code, not unless it is actually R010. When measured, it shows .2 ohm (starts with .5 then settles with .2) which i believe is wrong, it should be .01 ohm
Thanks!
Thanks!
