Please help !
tgotwalt1158
Joined Feb 28, 2011
110
also pleasse tell me how to program my PIC ? which is the best compiler in terms of taking the minimum time to learn ?
The PICSTART Plus development programmer is an easy-to-use, low-cost, prototype programmer. It connects to the PC via a COM (RS-232) port. MPLAB Integrated Development Environment software makes using the programmer simple and efficient. The PICSTART Plus development programmer supports most PIC micro devices up to 40 pins.
juhi1107
Joined Oct 11, 2011
17
Thank you everyone
I was surfing the net and I found an option for directly ordering a PIC development board. How useful is it ?
ErnieM
Joined Apr 24, 2011
8,415
Thank you everyone
That would depend on which board you found. :D
I would definitely recommend getting a dev board. You thus start with a wired and tested piece of hardware, and if it comes with sample programs you can build and run and tweak to something else all the better.
I don't recommend the PICSTART Plus, it cannot do debugging. Get a dev board that can use the PicKit (2 or 3).
tgotwalt1158
Joined Feb 28, 2011
110
That's right juhi1107! I am out of touch of MC programming since long time. Just informed you from my earlier recollections which might already be obsoleted, so plz do some research before buying any thing in this regard.
t06afre
Joined May 11, 2009
5,934
You do not realy need a development board. you need a programmer that can program your PIC. And that was a PIC16F877A if I remember correct. Then go for a PICKIT 3 or a PICKIT 2. Build your system so you can program the PIC in circuit. No need to take it in and out from circuit for programming.
juhi1107
Joined Oct 11, 2011
17
bertus
Joined Apr 5, 2008
22,995
The shown development board has an ICSP connector.
With this connector you can program the PIC in circuit.
Here is a page from sprits that shows some porgrammers and ICSP connections for pics:
http://www.sprut.de/electronic/pic/icsp/icsp.htm
As the page is in german I used google to translate it for you:
http://translate.google.com/translate?sl=de&tl=en&js=n&prev=_t&hl=nl&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.sprut.de%2Felectronic%2Fpic%2Ficsp%2Ficsp.htm&act=url
I see that the development board uses 6 pins in stead of the normal 5 pins.
As I am not familiar with pics I unfortunately can not tell what the extra pin does.
juhi1107
Joined Oct 11, 2011
17
hello everyone
There is some clarity now on how to go about the project.
Now I need to write the code in C .
Please help me out.
Basically I want to use 2 photo resistors compare their output and rotate the tracker in the direction of the one whose output is greater.
Please tell me how to connect to the PIC16f877a and how to program it.
thatoneguy
Joined Feb 19, 2009
6,359
Which vendor's C are you using?
Post your most recent schematic.
And, the most important question:
Have you learned humility? We are here to help out if we feel like it, not the other way around.
juhi1107
Joined Oct 11, 2011
17
@thatoneguy Thank you for your time. :) But I Didnt understand what put you off.
I am new to forums .. this is my first time. Bear with me please.
I am using MPLAB IDE and Hi Tech C
thatoneguy
Joined Feb 19, 2009
6,359
Do you have a PICKit 2 or PICKit 3?
If not, post when you have one, a PIC Kit is vital for programming, the DIY knockoffs cause more headaches than any $10 saved, $35 for the PICKit 2 from microchipdirect.com
thatoneguy
Joined Feb 19, 2009
6,359
Write a simple program, like blinking an LED.
If that works, you ae set.
There really isn't a "standard" for hooking up the extra parts you have, just pick I/Opins that you aren't using for something else, and talk to them with whatever interface they have (see datasheets for PIC and for your sensors to find what will work)
juhi1107
Joined Oct 11, 2011
17
yes a simple program for led blinking did work.
I dont know how to begin with the programmimg for using the inbuilt comparator.
I understand the logic but I dont know how to program it.
t06afre
Joined May 11, 2009
5,934
Start with the datasheet. Read the comparator section until you understand how to use it. That exercise is something all PIC programmer have to go through. Every time they want to do some programming
