I am wanting to wire some components together to have a sensor turn on an ionizer. I'm not a 100% sure on how to do it. The components are a Banner Q85vR3D-T9 diffuse sensor, a SMC VQ4100-5 air control valve, and a SMC IZN10-11P07 ionizer-nozzle type. I want to use 24v DC with no PLC. I want the sensor to to be flagged (turned on) and the ionizer will turn on to blow air. I understand the dip switches in the Banner sensor and can make adjustments if needed. I am doing this from scratch with no schematic to follow. If I had a drawling/schematic that I could follow I would be fine. But without one one I'm not sure if I could wire it correctly. I would appreciate any help and thank you.
