Help please, in identifying component,
tinkler
Joined Apr 29, 2023
Hi. My vintage, circa 1980, desktop paper folder is no more! Removed cover and found the top of this component blown off. I have no idea what is does but connected to the small drive motor. Spent days looking on net but to no avail. Can anyone help in identifying component, a source or equivalent replacement. thanks
AlbertHall
Joined Jun 4, 2014
12,652
It is an interference interference supressor normally connected to the AC power input.
The equipment should work normally without this component (except it may interfere with radio/tv)
If it still doesn't work then there is some other fault - fuse?
tinkler
Joined Apr 29, 2023
Thanks Albert. Never overlook the obvious, well I did! There is a fuse inside but if that blew then something still a cause unless fatigue as never changed. thanks, a job for next week
