Please help i only got another day for my research.
Ryka Thomas
Joined Dec 16, 2015
32
Hi i have a school project to do i must make a powerbank and it must have a microcontroller , so i would like to ask if it is possible to/could use my microcontroller to act as voltage regulator and a charge regulator .
Thanks in advance i will be pleased to answer any question :)
Colin55
Joined Aug 27, 2015
519
That's easy. We can design a Power Bank for you, controlled by a microcontroller, design the PC board, get the board made, build up a prototype and have it tested with 23 hours of soak-testing, all within a single day.
We will also have a voltage regulator and charge regulator incorporated in the project.
Expected cost will be about $5.50
22,099
Man
Do you ever work cheap! Doesn't even matter what kind of dollars they are. Who needs to outsource at those prices?
Kermit2
Joined Feb 5, 2010
4,159
The length of a day is based on a planets rotational velocity.
SO...... the earth has stopped spinning.
No applause. It was just simple logic. (Kermit takes a bow)
