Please help About this circuit! -Multiplier?
Zara Engineer
Joined Feb 6, 2015
53
Hello
I found this circuit in an old book , I've drawn the circuit .
With :
- F : clock signal 100 Hz
- M is a DC signal from -5 to +5
The author said that the result is M*F.
Please let me know
thanks in advance
Zara
DickCappels
Joined Aug 21, 2008
10,661
Please use a more description title next time.
It is a balanced modulator provided that you switch the non-inverting input to ground with your carrier F. This causes the circuit to switch between inverting and not inverting the signal as a function of the state of F.
Among other things, the swich can be a transistor if the base drive swings far enough below ground so that the collector-base junction does not become forward biased, with a MOSFET provided the capacitance is not to high, it can be a transmission gate (such 74HC4066) or a microcontroller out pin switched between being high impedance and ground if the signal is only a few hundred millivolts.
R2 and R3 should be equal.
MikeML
5,444
I have used that circuit as a synchronous detector (also known as a synchronous demodulator). Typically, you set the gain of the opamp to alternate between +1 and -1 as a function of the "carrier", which is a square wave with a 50% duty cycle.
Zara Engineer
Joined Feb 6, 2015
53
Hi guys
thanks for help
and sorry for mysterious title :)
but until now, i didn't understand by equation how can we have an output equal to F*M ? or F*Vin
I tried to put per example M = 0 ;
F = V+ = V-
that's mean that (0-F)/R2 = (F-Vout) /R3;
R2 = R3 = R;
=> Vout = 2 * F; ??
and about you it's F*M=F*0 = 0 ;
Please let me know what's the equation of output ! and an example please .
Thanks in advance.
Zara
MikeML
5,444
F is equal to + or -C, where C is a constant, like 1 or 1.345. It is not a true multiplier where C can be varied dynamically. (C cannot be a function of time)
joeyd999
Joined Jun 6, 2011
6,311
And I use the analogue in the digital realm for digital synchronous detection.
MikeML
5,444
Here is how to implement that function using an opamp. The switch shown is usually replaced with a FET. Note that the switch is closed when V(F)>0V; and is open when V(F)<=0V.
Can you see how the switch reconfigures the opamp so that its gain goes from +1 to -1?
