Please can this IGBT 60N60 work like this
hadewaleadelabu9
Joined Jan 27, 2020
22
NO, you will blow the transistors as they will turn on together and short out the supply.
You need to cross connect the Bases so that opposite transistors conduct, So top Left and Bottom Right bases , top Right and bottom Left.
just changed the transistors now with 60n60 1:1, but unfortunately it blown off
What could be the problem?
Top MOSFETs and bottom MOSFETs must never be on at the same time.
There must be a short time when no MOSFETs are on.
Bottom MOSFETs are driven by a driver sitting on (-).
Top MOSFETs is driven by a signal that is not related to (-) but by (AC)
Ian0
Joined Aug 7, 2020
13,271
Connect it like this,, put the coil across the collectors..
but connecting the gates like that will blow up the IGBTs.
Top left transistor will have 330V on its gate. Bottom right transistor has its source at 0V, so with 330V on its gate it won't last long.
No real advantage for this method (assuming the correct gate drivers) or the original. Both use four transistors. The original (half bridge) needs a capacitor in series with the winding, and operates at half the voltage and twice the current. This circuit (full bridge) operates with a higher voltage/lower current winding, requires no series capacitor but needs twice as many gate drivers.
UNLESS - it is a resonant power supply, in which case it DOES need the series capacitor.
shortbus
Joined Sep 30, 2009
10,049
If he is repairing a welder, not making one from scratch, he may be threw out the insulators for the IGBT's. Most of the welders I've seen the insides of have all of the transistors mounted on one big heat sink, but then they need to have insulators too. Someone with no experience may think they aren't needed and leave them out.
hadewaleadelabu9
Joined Jan 27, 2020
22
Please what type of insulator
this is the circuit of the project
IGBT Welder  (5).jpgIGBT Welder  (3).jpgIGBT Welder  (7).jpgIGBT Welder  (8).jpgIMG_20201102_085123.jpgIMG_20201102_085134.jpg123757981_389169675601133_6939331024051308955_n.jpgIGBT Welder  (2.jpg
shortbus
Joined Sep 30, 2009
10,049
Have you posted the brand and model of welder? I can't remember seeing it if you did. From one of your drawings it says 100amps, but several times you say you want to get 200amps out of the welder. You do understand the IGBTs will have no influence on the amperage out put of your welder don't you? The amperage output is dependent on the transformer in the welder, not any switching device in it.
Dodgydave
Joined Jun 22, 2012
11,395
I see you're trying to add extra transistors to make it work better, these transistors need insulation tabs as shown to isolate the Collector from the heatsink.
There are MOSFETs in a SOT 227 package.
shortbus
Joined Sep 30, 2009
10,049
IGBT's are also available in that package. Not heat sink insulator needed, That, SOT 227 package is what most industrial welders and plasma cutters use.
But still don't think he can double his output by just changing the switches/transistors.
hadewaleadelabu9
Joined Jan 27, 2020
22
I wasn't trying to double the output, the former 50T65 has burnt off, but I can only find 60n60 to replace it, now that I did the 60n60 has burnt off again
hadewaleadelabu9
Joined Jan 27, 2020
22
Does insulator really needed in this ?
shortbus
Joined Sep 30, 2009
10,049
Are you asking about the SOT-227? Or the T-247?
SOT-227. The metal mounting base is insulated from all of the internal parts of the transistor. Needs no extra insulator but does need thermal past between the base mount and the heatsink.
T-247. The flat metal base of the transistor is a "live" part of the transistor. It needs a pad/insulator, but not the insulator bushing that comes in a insulator kit. The mounting hole in that package has plastic surrounding it. But you also need thermal paste between the transistor and pad plus between pad and heatsink.
But you still haven't answered my question. Are you expecting by just changing to a higher rated transistor to get a higher welding amperage? It won't happen. The transistors have nothing in them that will make any magic amperage, none.
hadewaleadelabu9
Joined Jan 27, 2020
22
No, I was just trying to find the good and equivalent transistors that will suit the work
hadewaleadelabu9
Joined Jan 27, 2020
22
I can't get thermal paste or pad/insulator in my area is there any alternative please ?
