Piezo Transducer Driver Circuit
h.yakub
Joined Mar 11, 2019
97
I have just download the zip and it works OK for me.??
What format is different.?
E
It is .mod file, I copy pasted the 3 files to lib folder and started the .asc file you sent, but still showing error that the components not found..!!..Is there any step that I am missing?..
h.yakub
Joined Mar 11, 2019
97
hi,
Do you have a colleague who is familiar with LTSpice.?
It will be quicker to find the problem at your end.
E
No, no one is familiar with LTSpice. But I am finding, I got the issue..I am fixing it...
I am not able to edit the 2n7002 model, I have fixed the fatal error problem, but when i tried to edit the 2n7002 model, it say's component cannot be edited...!
Solved, I am able to simulate the results now..:)
h.yakub
Joined Mar 11, 2019
97
hi,
Edited
E
Hi EricGibbs,
Please check the following .asc file and provide your output on it.
Also, I guess the circuit that we designed is simulating well, but the only thing is the transducer could get an echo back from the container. Any idea is to what else can we do so that we could get echo back from inside the steel container.
ericgibbs
Joined Jan 29, 2010
21,591
hi,
I will at the simulation,
Why have you have changed the TX circuit back to the original design.? also you have two transducers across the pz to 0v output.
Both of the transducers are not a correct representation of a real transducer.
E
