PIC18F45k80 ADC Module
Djsarakar
Joined Jul 26, 2020
489
Hi
I am reading datasheet of PIC18F45k80 for ADC Module. ADCs convert analog signal into digital signal Detail information is given in chapter 23. Page 350
I am trying to understand block diagram I don't understand block diagram for ADC module
FIGURE 23-4: A/D BLOCK DIAGRAM
hexreader
Joined Apr 16, 2011
619
Start simple by selecting options that turn a complicated ADC into a simple one.
1) Set VNCFG bit to 0 to select Vref- to be Vss
2) Set VCFG to 00 to select Vref+ to be Vdd
3) Set CHSN to 000 to select negative input AVss - make sure that PIC AVss pin is connected to ground
4) Set CHS to select desired analogue input pin
You now have a simple ADC which accepts 0 to 5V input and gives a number proportional to that voltage
5) Connect onboard pot to chosen analogue input for test purposes - put 1000 Ohm resistor in series as your development board does not have any protection resistor on-board
6) Write some clever code to get ADC value to desired output device (or borrow somebody else's code to base yours on)
Not tried any of this for myself, but this is my understanding of the datasheet - could be wrong
Djsarakar
Joined Jul 26, 2020
489
What is it that you do not understand?
What is it that you want to know?
The 12bit ADC divides the range of voltage. A 12 bit A/D will take a 0 to 5 volt input and convert it to 2^12 bits or offer up 0 to 4096 bits or quantization levels.
I want to know the 12bit ADC divides the range of voltage
35,093
The 12-bit ADC digitizes a voltage in the range 0-5V and returns a 12-bit value. There are 4096 possible values corresponding to 4096 voltage steps.
One step size is 5V/4096.
Djsarakar
Joined Jul 26, 2020
489
Hi MrChips
Can you tell me when should be select special select trigger bits
hexreader
Joined Apr 16, 2011
619
Spoiler alert: rubbishy, but working code is below (I got bored)
Do not scroll down if you want to work it out for yourself.
I am not proud of this code, so you have plenty of opportunity to improve it.
Read instructions commented at top of code.
Code:
// random code UART code found on forum
// read ADC input and print result on UART
// updated by amateur hobby programmer - use at own risk - update author accepts no responsibility for anything
// 9600 baud - connect RC6 to Rx, RC7 to Tx
// connect on-board pot to RA0
// Status 23 October 2020
//   - Commenting not complete yet
//   - TAD is probably far longer than needed - need to reduce
//   - code is very amateur and messy - needs improvement
#define _XTAL_FREQ 20000000     // 2-pin crystal 20MHz
// PIC18F45K80 Configuration Bit Settings
// CONFIG1L
#pragma config RETEN = ON       // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW  // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF      // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2       // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF     // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF       // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON      // Power Up Timer (Enabled)
#pragma config BOREN = OFF      // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0         // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW     // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1        // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC    // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5   // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = ON      // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = OFF     // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K     // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON         // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON         // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON         // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON         // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON         // Code Protect Boot (Enabled)
#pragma config CPD = ON         // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON        // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON        // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON        // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON        // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON        // Config. Write Protect (Enabled)
#pragma config WRTB = ON        // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON        // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON       // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON       // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON       // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON       // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON       // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
// global variables
unsigned char txt_buf[10];                                                      // general purpose text buffer
void Port_Initialized (void)
    ANCON0 = 0x01;                                                              // AN0 analogue, rest digital
    ANCON1 = 0;        // Set to digital port
    CM1CON = 0;        // Comparator off
    CM2CON = 0;        // Comparator off
    ADCON0 = 0;        // A/D conversion Disabled
    ADCON1 = 0;        // A/D conversion Disabled
    ADCON2 = 0;        // A/D conversion Disabled
    LATA =  0;
    LATB =  0;
    LATC =  0;
    LATD =  0;
    LATE =  0;
    TRISA = 0b0000001;                                                          // A0 input, rest output
    TRISB = 0b0000000;                                                          // all are output, Unused
    TRISC = 0b0000000;                                                          // C0-C5 output - C6=Tx, C7=Rx
    TRISD = 0b0000000;                                                          // all are output, Unused
    TRISE = 0b0000000;                                                          // All are output, Unused
void send(char message)
    while(TXIF == 0 );                                                          // Wait till the transmitter register becomes empty
    TXREG1 = message;
void string(char *p)
   while(*p != '\0') {
       __delay_ms(1);
     send(*p);
     p++;
void Uart_Initialized(void)
    //TXSTAx TRANSMIT STATUS AND CONTROL REGISTER
    TXSTA1bits.CSRC = 0;                                                        //: Don?t care.
    TXSTA1bits.TX9 = 0;                                                         // Selects 8-bit transmission bit
    TXSTA1bits.TXEN = 1;                                                        // Transmit Enable
    TXSTA1bits.SYNC  = 0;                                                       // Asynchronous mode
    TXSTA1bits.SENDB = 0;
    TXSTA1bits.BRGH =  1;                                                       // High speed mode
    TXSTA1bits.TX9D = 0;
    //RCSTAx: RECEIVE STATUS AND CONTROL REGISTER
    RCSTA1bits.SPEN  = 1 ;                                                      // Serial port enabled
    RCSTA1bits.RX9 = 0;                                                         // Selects 8-bit reception
    RCSTA1bits.SREN  = 1 ;                                                      // Don?t care.
    RCSTA1bits.CREN  = 1 ;                                                      // Enables receiver
    RCSTA1bits.ADDEN = 0;                                                       //
    RCSTA1bits.FERR  = 0 ;                                                      // No framing error
    RCSTA1bits.OERR  = 1 ;                                                      // Overrun error
    RCSTA1bits.RX9D   = 0 ;                                                     // Selects 8-bit reception
    SPBRGH1 = 0;
    SPBRG1 = 129,
    INTCON = 0x00;
    PIR1 = 0x00;
    PIR2= 0x00;
    PIR3 = 0x00;
    PIR4 = 0x00;
    PIR5 = 0x00;
    PIE1 = 0x00;
    PIE2 = 0x00;
    PIE3 = 0x00;
    PIE4 = 0x00;
    PIE5 = 0x00;
    IPR1 = 0x00;
    IPR2 = 0x00;
    IPR3 = 0x00;
    IPR4 = 0x00;
// convert raw ADC reading to ASCII decimal
// quick, dirty code - needs replacing with an elegant itoa routine
void ADC_to_ASCII(unsigned int adc_raw){
  unsigned char thousands;
  unsigned char hundreds;
  unsigned char tens;
  unsigned char units;
  unsigned int temp_raw;
    temp_raw = adc_raw & 0x0fff;                                                // limit to 4095 max
    thousands = temp_raw/1000;
    temp_raw = temp_raw - (thousands * 1000);
    hundreds = temp_raw/100;
    temp_raw = temp_raw - (hundreds * 100);
    tens = temp_raw/10;
    temp_raw = temp_raw - (tens * 10);
    units = temp_raw;
    txt_buf[0] = 0x20;                                                          // space
    txt_buf[1] = 0x20;                                                          // space
    txt_buf[2] = thousands + '0';
    txt_buf[3] = hundreds + '0';
    txt_buf[4] = tens + '0';
    txt_buf[5] = units + '0';
    txt_buf[6] = 0x0d;                                                          // CR
    txt_buf[7] = 0;                                                             // null terminate the string
// initialise ADC for channel 0 - 0 to 5 Volts input to RA0
void ADC_Init(){
    ADCON0 = 0x00;                                                              // channel 0 ADC off
    ADCON1 = 0x00;                                                              // voltage limits Vss Vdd
    ADCON2 = 0xbe;                                                              // right justify, 20 TAD, Fosc/64
    ADCON0 = 1;        // enable ADC
    txt_buf[0] = 0x0d;                                                          // CR
    txt_buf[1] = 0x0a;                                                          // LF
    txt_buf[2] = 0x0a;                                                          // LF
    txt_buf[3] = 0;                                                             // null terminate the string
        string(txt_buf);                                                        // send to UART
// read ADC value on RA0
unsigned int Read_ADC(void){
    unsigned int retval;
    while(ADCON0 & 0x02);                                                       // wait for conversion to finish
    LATD = ADRESL;                                                              // debug only low result to PORT D LEDs
    LATC = ADRESH *4;                                                           // debug only high result to PORT C LEDs C2 to C5
    retval = (unsigned int)(( ADRESH << 8) + ADRESL);                           // combine high and low values
    ADCON0 = 3;        // start next conversion
    return retval;
void main(void)
    unsigned int ADC_result;
    Port_Initialized ();
    Uart_Initialized ();
    ADC_Init();
    while (1)
        ADC_result = Read_ADC();                                                // get ADC result from RA0
        ADC_to_ASCII(ADC_result);                                               // convert to decimal ASCII string
        __delay_ms(300);                                                        // limit sample rate
Djsarakar
Joined Jul 26, 2020
489
Hi hexreader
I was trying to understand detail about ADC module that's why posted block diagram It's seem you have copied the code of uart that I have posted on microchip forum. Please do not post code directly help me to understand basic so that I will try to write code myself
jpanhalt
Joined Jan 18, 2008
11,087
Hi hexreader
I was trying to understand detail about ADC module that's why posted block diagram. <snip> Please do not post code directly help me to understand basic so that I will try to write code myself
Since you are trying to learn about the module, what have you done to help yourself? I believe this thread meets the definition of homework.
Why would you want to trigger an ADC? Have you ever searched on the subject? Maybe if you entered the following in your favorite search engine, you would gain some insight: PIC 18F ADC special event triggers
In case you need help in that, here are a few examples:
http://ww1.microchip.com/downloads/en/appnotes/pic16-pic18-adc2-90003194a.pdf (introduction to ADC)
https://www.microchip.com/forums/m1057912.aspx
https://forum.allaboutcircuits.com/threads/pic18f-adc-using-timer-interrupt.154042/
https://www.microchip.com/forums/m546158.aspx
https://www.microchip.com/forums/m880062.aspx
geekoftheweek
Joined Oct 6, 2013
1,429
The special trigger bits cause the ADC to start a conversion based on the trigger selected. An example would be to start a conversion every time Timer1 rolls over. The diagram itself is more or less just a graphical representation of some bits in the various ADC registers.
jpanhalt
Joined Jan 18, 2008
11,087
You cannot opt out.
The default setting is 00.
My understanding is that while a special event trigger must be selected, it does not need to be used. Section 23.8 describes settings for those trigger sources, if used. One can control acquisition and processing independent of the special triggers with the ADCON0 register bit<1> ("GO/!DONE").
Thus, while one might have liked a "none" option, it is not really necessary. Just leave the default and don't set up CCP2 to be a trigger, etc.
hexreader
Joined Apr 16, 2011
619
A0 Pot at minimum ( 0.3 mV) - values in decimal
0019
0019
0018
0018
0019
0018
0018
0018
0019
0018
0018
0019
0019
0018
0018
0018
0018
0018
0018
0018
0019
0018
0018
0018
0018
0018
0018
0018
0019
0018
0018
0019
0019
0018
0018
0018
0018
0019
0018
0019
0018
0018
0018
0019
0018
0019
A0 POT at maximum ( 4.97V )
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
4095
A0 POT at centre ( 2.22 V )
1842
1844
1840
1844
1838
1841
1842
1837
1839
1839
1840
1845
1845
1839
1844
1844
1843
1842
1844
1842
1838
1844
1845
1845
1844
1836
1844
1840
1838
1837
1840
1847
1846
With, or without 10uF capacitor on Vcap - makes no difference
hexreader
Joined Apr 16, 2011
619
Extract from errata sheet for this device (ID 6)
" The 12-bit A/D performance is outside the data sheet’s A/D Converter specifications. When used as a 12-bit A/D, the possible issues are: high offset error, up to a maximum of ±25 LSBs at 25°C, ±30 LSBs at 85°C, 125°C and -40°C; high DNL error, up to a maximum of +6.0/-4.0 LSBs; and multiple missing codes, up to a maximum of twenty. Users should evaluate the 12-bit A/D performance in their application using the suggested work around below. See Table 3 for guidance specifications. "
So the reading of about 16 decimal (0x10 hex) for zero volts input might be explained by the above
hexreader
Joined Apr 16, 2011
619
Yes
ANI 1 or ANI 2 (ANI means ANalogue Input)
Taking long wires out to breadboard will increase the noise. Expect a bit of noise whatever wiring you choose
Expect lowest ADC result to be about 0x10 hex due to the problem described in errata sheet
What is the value of each of the two on-board potentiometers? 10K Ohms ?
Djsarakar
Joined Jul 26, 2020
489
1842
1844
1840
1844
1838
1841
1842
1837
1839
1839
1840
1845
1845
1839
1844
1844
1843
1842
1844
1842
1838
1844
1845
1845
1844
1836
1844
1840
1838
1837
1840
1847
1846
I have connected A0 / RA0 into AN11
A0 POT at center ( 2.50 V )
why I am getting unknown readings ?
Edit : I measured output voltage of pot 2.50 v but I get 50m volt at RA0 pin
