@hexreader I am going to shorting the battery terminals with a 100R. I have very poor understand to read layout.Your battery connection appears to be floating.
I see old threads on the Microchip forum that seem to suggest that DS1307 will not work with pin 3 (Vbat) unconnected.
I will purchase but for now its not available in the local market. if I order online it will take one or two moths because of covid[/QUOTE]Why not do a proper job and buy a battery holder and battery? A clock with no battery is a useless device.
Yes Now I'm thinking exactly same. I have tried everything as per my best knowledge but I could not solved problem. I was getting error code 0x02 that means no acknowledgement from IN1307.If your immediate goal is to get the I2C link up and debugged, you could use the 24C04 EEPROM. Except for the slave addresses, the EE and RTC have the same I2C format. Treat the first 8 bytes of the EE as the 8 registers of the RTC. The only other difference is you need to wait 10msec after writing the EE.
I would just add wires to connect both SDA together and both SCL together then use the same pullups for both chips to make an I2C bus. Connect the resulting I2C bus to the PIC in the normal way. Pull the RTC chip from the socket to keep it from affecting the I2C signals until you get the rest working. Use your multimeter to verify +5V at SCL and SDA when idle then turn power off and verify proper connections to the PIC.For 24C04 EEPROM I have to desolder pull resistor that I was using for ds1307.
//Send one byte. Return 0 if ACK received, or 1 if NAK received
__bit I2C_Sendbyte(unsigned char dat)
SSPBUF = dat;
asm("nop"); // <<<--- wait a little for R_W to be set
while (R_W); //wait until byte sent and ACK/NAK received
return ACKSTAT;
@JohnInTX Thank you for help. I tried the code with calling Port_Initialized()@Djsarakar 's problem since it is a different PIC but after adding the NOP, the rest of the code runs without issue.
ALSO: in the code snippet posted in #149 you are not calling Port_Initialized() to initialize your IO.
Good luck!
Did you add the NOP?@JohnInTX Thank you for help. I tried the code with calling Port_Initialized()
But I am getting error code 0x02.
@JohnInTX I was not sure yet that there is problem with program or in the program.I don't know for sure if that is @Djsarakar 's problem since it is a different PIC but after adding the NOP, the rest of the code runs without issue.
#define _XTAL_FREQ 20000000 // crystal 20MHz
// PIC18F45K80 Configuration Bit Settings
// CONFIG1L
#pragma config RETEN = ON // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2 // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON // Power Up Timer (Enabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0 // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1 // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5 // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON // Code Protect Boot (Enabled)
#pragma config CPD = ON // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON // Config. Write Protect (Enabled)
#pragma config WRTB = ON // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define ADS1115_ADDRESS 0x90 //address of ADS1115 with write mode (
unsigned char Result;
void Port_Initialized (void)
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
TRISA = 0x00; // All are output, Unused
TRISB = 0x00; // all are output, Unused
TRISD = 0x00; // all are output, Unused
TRISE = 0x00; // All are output, Unused
ANCON0 = 0x00; // digital
ANCON1 = 0x00; // Set to digital port
CM1CON = 0x00; // Comparator off
CM2CON = 0x00; // Comparator off
ADCON0 = 0x00; // A/D conversion Disabled
ADCON1 = 0x00; // A/D conversion Disabled
ADCON2 = 0x00; // A/D conversion Disabled
//Initialize I2C in master mode
void I2C_Initialized(void)
TRISCbits.TRISC3 = 1; // Clock Pin
TRISCbits.TRISC4 = 1; // SDA Pin
SSPSTAT=0x80; //Slew rate control is disabled for Standard Speed mode (100 kHz and 1 MHz)
SSPCON1=0x28; // I2C Master mode, clock = FOSC/(4 * (SSPADD + 1))
SSPCON2=0x00;
SSPADD = 49; //100kHz clock @ 20MHz Fosc SSPADD = ( (Fosc/4) / BiteRate )-1
// SSPADD = ( 20MHz / 100KHz ) - 1 = 49 //
// Send an I2C START
// Return 0 if all ok, 1 if bus collision
__bit I2C_Start(void)
BCLIF = 0; //Clear 'Bus collision" flag
SEN = 1; //initiate a START cycle
while (SEN); //wait until it has been sent
return BCLIF; //return value of BCLIF flag
// Send an I2C STOP
void I2C_Stop(void)
PEN = 1; //initiate a STOP cycle
while (PEN); //wait until it has been sent
// Send an I2C REPEATED START
void I2C_Restart(void)
RSEN = 1; //initiate a REPEATED START cycle
while (RSEN); //wait until it has been sent
//Receive one byte. ackflag=0 to send ACK, or 1 to send NAK in reply
SSPBUF = dat;
return ACKSTAT;
unsigned char I2C_Recvbyte(unsigned char ackflag)
RCEN = 1; // initiate a RECEIVE cycle
ACKDT = ackflag; //specify if we should send ACK or NAK after receiving
while (RCEN); //wait until RECEIVE has completed
ACKEN = 1; //initiate an ACK cycle
while (ACKEN); //wait until it has completed
return SSPBUF;
//Send address one byte address of I2C device.
//Return 0 if all OK, 1 if bus error, 2 if slave address NAK,
unsigned char ADS1115_Write(unsigned char slave_address)
if (I2C_Start() ) //send a start, and check if it succeeded
return 1; //abort if bus collision
//send the I2C slave address (force R/W bit low)
if (I2C_Sendbyte(slave_address))
I2C_Stop(); //if address was NAKed, terminate the cycle
return 2; //and return error code
I2C_Stop();
return 0; //no error
void main(void)
Port_Initialized ();
I2C_Initialized();
Result = ADS1115_Write(ADS1115_ADDRESS);
while(1);
