That chip uses an I2C interface so yes, pullups are REQUIRED on SCL and SDA. 4.7K is a good value to start with.I want to use IN1307 on module
Are pullup resistors on SDA and SCL are REQUIRED to communicate with on board IN1307 module ?
HiFWIW, the IN1307E looks like a knock-off of the standard Maxim DS1307. Search AAC for DS1307 - there are several threads about it. Here's the datasheet for the Maxim part. It describes the functions and I2C transactions in better detail.
Read read.
The picture is kind of hard to follow because the wires obscure some of the connections but its looks right assuming you have found the right PIC pins for SDA and SCL on the header.Hi
I am attaching picture for pull up resistor. And I hope all the connection I hame are correct
Resistor 4k7
Here is program for I2CThe picture is kind of hard to follow because the wires obscure some of the connections but its looks right assuming you have found the right PIC pins for SDA and SCL on the header.
#define _XTAL_FREQ 20000000 // crystal 20MHz
// PIC18F45K80 Configuration Bit Settings
// CONFIG1L
#pragma config RETEN = ON // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2 // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON // Power Up Timer (Enabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0 // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1 // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5 // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON // Code Protect Boot (Enabled)
#pragma config CPD = ON // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON // Config. Write Protect (Enabled)
#pragma config WRTB = ON // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define IN1307_ADDR 0xD0 //I2C slave address of DS1307 (8 bit format)
#define SECONDS_REG 0 //offset of the "seconds" register in the DS1307
void Port_Initialized (void)
ANCON0 = 0; // digital
ANCON1 = 0; // Set to digital port
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
ADCON1 = 0; // A/D conversion Disabled
ADCON2 = 0; // A/D conversion Disabled
LATA = 0;
LATB = 0;
LATC = 0;
LATD = 0;
LATE = 0;
TRISA = 0b0000000; // AN0 as input,
TRISB = 0b0000000; // all are output, Unused
// TRISC = 0b0001100; //
TRISD = 0b0000000; // all are output, Unused
TRISE = 0b0000000; // All are output, Unused
//Initialize I2C in master mode, Sets the required baudrate
void I2C_Init(void)
TRISCbits.TRISC3 = 1;
TRISCbits.TRISC4 = 1;
SSPSTAT=0x80; //Slew rate control is disabled for Standard Speed mode (100 kHz and 1 MHz)
SSPCON1=0x28; // I2C Master mode, clock = FOSC/(4 * (SSPADD + 1))
SSPCON2=0x00;
SSPADD = 49; //100kHz clock @ 20MHz Fosc
// Send an I2C START
// Return 0 if all ok, 1 if bus collision
__bit I2C_Start(void)
BCLIF = 0; //Clear 'Bus collision" flag
SEN = 1; //initiate a START cycle
while (SEN); //wait until it has been sent
return BCLIF; //return value of BCLIF flag
// Send an I2C STOP
void I2C_Stop(void)
PEN = 1; //initiate a STOP cycle
while (PEN); //wait until it has been sent
// Send an I2C REPEATED START
void I2C_Restart(void)
RSEN = 1; //initiate a REPEATED START cycle
while (RSEN); //wait until it has been sent
//Send one byte. Return 0 if ACK received, or 1 if NAK received
__bit I2C_Sendbyte(unsigned char dat)
SSPBUF = dat;
while (R_W); //wait until byte sent and ACK/NAK received
return ACKSTAT;
//Receive one byte. ackflag=0 to send ACK, or 1 to send NAK in reply
unsigned char I2C_Recvbyte(unsigned char ackflag)
RCEN = 1; // initiate a RECEIVE cycle
ACKDT = ackflag; //specify if we should send ACK or NAK after receiving
while (RCEN); //wait until RECEIVE has completed
ACKEN = 1; //initiate an ACK cycle
while (ACKEN); //wait until it has completed
return SSPBUF;
//Send an array of data to an I2C device.
//Return 0 if all OK, 1 if bus error, 2 if slave address NAK, 3 if slave register NAK, 4 if slave data NAK
unsigned char I2C_Writeblock(unsigned char slave_address, unsigned char start_reg, unsigned char buflen, const unsigned char * bufptr)
if (I2C_Start() ) //send a start, and check if it succeeded
return 1; //abort if bus collision
//send the I2C slave address (force R/W bit low)
if (I2C_Sendbyte(slave_address & 0xFE))
I2C_Stop(); //if address was NAKed, terminate the cycle
return 2; //and return error code
//send the device register index
if (I2C_Sendbyte(start_reg))
I2C_Stop(); //if register was NAKed, terminate the cycle
return 3; //and return error code
//send the data. buflen might be zero!
for (; buflen>0; --buflen)
if (I2C_Sendbyte(*bufptr++))
return 4; //and return error code
I2C_Stop();
return 0; //no error
//Receive an array of data from an I2C device.
unsigned char I2C_Readblock(unsigned char slave_address, unsigned char start_reg, unsigned char buflen, unsigned char * bufptr)
//do a dummy zero length write cycle to set the register address
unsigned char retval = I2C_Writeblock(slave_address, start_reg,0,0);
if (retval)
return retval; //abort if there was an error
//now start the READ cycle
//send the I2C slave address (force the R/W bit high)
if (I2C_Sendbyte(slave_address | 0x01))
//receive the data.
unsigned char ackflag = (buflen == 1); //1 if this is the last byte to receive => send NAK
*bufptr++ = I2C_Recvbyte(ackflag);
I2C_Stop();
const unsigned char rtc_data[] =
0x56, //56 seconds
0x34, //34 minutes
0x12, //12 hours & 24 hour mode
0x01, //01 day=Sunday
0x03, //03 date
0x12, //12 month=dec
0x01, //01 year=2001
unsigned char rd_buf[7];
void main(void) {
I2C_Init();
unsigned char w;
unsigned char r;
w = I2C_Writeblock(IN1307_ADDR, SECONDS_REG, sizeof(rtc_data), rtc_data);
r = (I2C_Readblock(IN1307_ADDR, SECONDS_REG, sizeof(rd_buf), rd_buf) );
while(1); //endless loop to avoid exiting main() function)
It was my mistake Nothing is connected to port AWhat is connected to PORTA,0?
PORTA is an 8-bit port, why are you only setting 7 of those bits. None are set to input. Check your other ports too.
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#include <xc.h>
LATA = 0;
LATB = 0;
LATC = 0;
LATD = 0;
LATE = 0;
TRISA = 0b00000000; // all are output unused
TRISB = 0b00000000; // all are output, Unused //
TRISD = 0b00000000; // all are output, Unused
TRISE = 0b00000000; // All are output, Unused
void I2C_Init(void)
SSPCON2=0x00;
// Send an I2C STOP
void I2C_Stop(void)
SSPBUF = dat;
return ACKSTAT;
return SSPBUF;
I2C_Stop();
if (retval)
//receive the data.
I2C_Stop();
0x56, //56 seconds
0x34, //34 minutes
0x03, //03 date
void main(void) {
I2C_Init();
unsigned char w;
unsigned char r;
morning JohanInTXAre you running the simulator or the actual chip hardware? (The simulator does not simulate the MSSP),
I don't understand this process so if I remove both PIC18f45k80 and IN1307 from the chip How the test will happenIf it were me, I would remove both of the I2C chips from their sockets and get to the point where I could sent Start, slave address, get the NAK (from no chips) and send stoP, leaving the bus at 1,1 (idle). When you get that far, put in one chip and go from there. You want to avoid any issues from the chips while you are debugging the basics.
@JohnInTX @hexreader There is no pull up resistors on the board for IN1307. and I don't have resistor bank I have only two 4.7 K resistorThe picture is kind of hard to follow because the wires obscure some of the connections but its looks right assuming you have found the right PIC pins for SDA and SCL on the header.
@hexreader Thank you for clarification Do you have DS1307 RTC ?What you show is correct.
@hexreader Thanks. Can you post your c code with comments, not a hex file ?Yes, I have DS1307 and PIC18F45K80.
I use mikroC compiler and library.
