Physical Rg6 cable voltage and amperes ratings
Edwin95
Joined Sep 7, 2024
13
If you want to find the voltage and amperes from an f81 connector connected between receiver and multiswitch and your left off with only the physical rg6 cable that was connected between multiswitch and lnb can you find out how many voltage and amperes the f81 connector received? What specific information is needed? What tool is needed to find the ratings of volts and amps of the physical rg6 cable itself due to it's label faded away by dust?
RG6 is not a power transmsission rated cable. 1A and maybe 30V are typical MAX power use ranges in communications applications. It will likely take several hundred volts AC, with a 18 gauge solid copper center, the ampacity is 14A. If the inner shields are a equivalent wire gauge. I would not use it at those voltage and current ranges.
https://catalog.belden.com/techdata/EN/7916A_techdata.pdf
How would you describe this satellite TV installation here's a photo diagram example. It's a dish network dishpro 301 system.
Typical communications application, 21V @ 200mA. The cable carries DC power for the switches and the LNB module at the feedhorn on the sat dish.
https://www.satellitebg.com/satellite-products/lnb-lnbf/dish-pro-lnbf-detail
Description
Specification
Input frequency range11.7 ~ 12.75 GHz
Reflector type offsetYes
F/D ratio0.5~ 0.7
Cross pol. isolation20 dB (minimum)
Noise figure0.6 dB (typical)
Conversion gain62 dB (typical)
Gain flatness±0.5 db / 27 MHz
Output frequency950~2000 MHz
L.O. frequency11.25 Ghz
L.O. frequency stability ( 1 )± 1 MHz ( room temperature )
L.O. frequency stability ( 2 )± 3 Mhz ( -40 to +60 ) ℃
L.O. phase noise-50 dBc / Hz ( @ 1KHz )
L.O. phase noise-80 dBc / hz ( @ 10KHz )
L.O. phase noise-100 dBc / Hz ( @ 100KHz )
Output power level (at 1 dB gain compression)0 dBm (minimum)
Image rejection45 dB (minimum)
Output vswr2.5 : 1 (maximum)
Output connector75 f type female Ω
DC current consumption200 mA
Operating voltageR.H. circular polarization :10.5 ~ 14 V | L.H circular polarization :15.5 ~ 21 V
Operating temperature-40 ℃ ~ +60 ℃
I have a RF switching matrix of the cables and switches from my FTA days when you could easily crack DISH encryption. It was just a personal hobby playing cat and mouse with their countermeasures, still have my HH (to move the dish automatically across all the geosync birds at my location) system online for most sat bands, modulations and polarities of RF waves..
https://forum.allaboutcircuits.com/threads/super-moon-shine.100322/post-900065
It was original a Primestar dish. https://en.wikipedia.org/wiki/PrimeStar
Old PrimeStar satellite dishes are popular among hobbyists for free-to-air (FTA) satellite broadcasts on the Ku band transponders of FSS satellites.
The dishes are also popular for wireless computer networking as high-gain Wi-Fi antennas. The antennas are also used by amateur (ham) radio operators to transmit two-way amateur television.
My original DISH conversion pictures with the original LNB
https://www.satelliteguys.us/xen/threads/primestar-dish-on-sg2100.23072/post-637356
DIY dish clamp and tracking adjustment adapter for Horizon to Horizon dish reception pointed at GEO orbit.
Multi LNB feedhorn update I'm using now.
At least 18 years of usage. A little moss and rust from the PWN rain.
HH motor power is also supplied from the RG6 cable.
DM2800 Opticum DiSEqC H to H Motor and Mount
Compatiable with All DiSEqC 1.2 Receivers
Drive Satellite Dish up to 1.4 Meters (30lbs Maximum) at High Speed
Quick Installation by only 1 Coax Cable to power both the Motor and the LNBF
DiSEqC 1.3/"Go To X (USALS) function" 60 positions
Metal Gear
Motor Shaft - 2" / 50MM OD
Adjustable Hardware Limits
Easy Installation with LED Indicator
Manual EAST / WEST button
Adjustable Dish Tube / Shaft
For Dish up to 1.4 Meters
Motor rotation angle: 150° (80° East ~ 80°West) max.
Rotation speed: 1.9°/s(13V) 2.5°/c(18V)
Power consumption: 50 mA (Standby) / 200 mA (Normal operation) / 350 mA (Maximum)
FTA channel scan today with my movable DISH.
