I would like to build something similar to a linear armature motor.
My google searches and book reading have come to naught on this issue - I'm obviously niether using the right search terms online nor checking the good chapters.
I wish to calculate physical force between two concentric coils given the ampere-turns of each and the distance.
Specifically:
if I wind N1 turns on a pipe (avg coil dia D1) and supply A1 amps dc through it,
and I have N2 turns on a rod inside the pipe (avg coil dia D2) with A2 amps dc through,
then how hard will the rod be pushed/pulled?
(Let's assume that there are L millimeters between the midpoint of each coil, and that each coil is much longer than D. I suspect that permeabilities of the pipe and rod will make a difference as well.)
Specifically:
