Phototransistors - question - not really homework
Wolframore
Joined Jan 21, 2019
2,619
Concerning Phototransistors... is there an actual base current since light activates the base? The reason why I ask is that with standard transistors:
Ie = Ic + Ib. Is the collector current the same as emitter current or is there an actual flow of electrons through the optical base? Am I the only one confused by this?
Wolframore
Joined Jan 21, 2019
2,619
Thanks @ericgibbs this is very descriptive but still not sure if I have more current in the emitter vs collector like it is in a standard BJT. My guess is the current through the emitter is the same as collector current but it’s not clear.
The bias current path for base current is from the collector when photonic energy is absorbed by the base and creates a leakage (resistive) path on the reversed CB junction by creating extra conduction holes.
Wolframore
Joined Jan 21, 2019
2,619
So Ic = Ie in this case! But the concern is that there's actually a base current separate from the collector current (induced by photons) and Kirchhoff says the sum=0...
dl324
Joined Mar 30, 2015
18,491
There is a base current. It's from the photons striking the collector-base junction.
From your first post:
Ie = Ic x Ib.
I know you meant '+' instead of 'x', but you might want to correct it before you have more peer corrections.
Wolframore
Joined Jan 21, 2019
2,619
ugh... you're right... edited. and so the emitter current must be the sum of both... my textbook is wrong again! hah... instructor says I get no extra points for pointing out errors in the textbook but it's a little frustrating at times.
dl324
Joined Mar 30, 2015
18,491
Can you post the section in question?
You can contact the author so s/he can correct it in a future revision. And your instructor could make note of it so s/he can point it out to students who might otherwise be confused.
Wolframore
Joined Jan 21, 2019
2,619
Let me try to get that one together... it's actually in two areas... first describing Collector current is the product of Beta and base current... but later he asks what the emitter current is and says it's the Collector current.
Another revision means another $200 for text books for students... I caught another one where a battery did not specify value and asked such as: This one the answer is that the current would increase... my answer was as long as the battery is enough to forward bias D1, I (D2) would increase.
dl324
Joined Mar 30, 2015
18,491
If you already have the book, you can just mark the correction. I've had instructors point out errors in textbooks so we could make the corrections ourselves.
Some books have the same errors revision after revision. AOE is one of them. I think version 2 had an error about the beta to use for operation a transistor in saturation mode. Version 3 has the same error; though slightly less wrong with a more elaborate (but still incorrect) discussion.
Wolframore
Joined Jan 21, 2019
2,619
There are two versions of this book. One for conventional current and the other electron flow. I hate how it goes back and forth at times. It’s ok as long as you are driven to find the correct answers. To be totally honest I didn’t even buy the book. I tried to find the author but his contact isn’t listed.
38,920
Current can't be created from nothing so obviously the collector and emitter currents must be equal if there is no external base connection.
The photoelectron "base" current is generated at the collector-base junction and is part of the collector and emitter current.
So technically a small portion of the collector current becomes the base current.
Thus I believe the book is correct.
Wolframore
Joined Jan 21, 2019
2,619
Current can't be created from nothing so obviously the collector and emitter currents must be equal, if there is no external base connection.
Book states: (this is all it states on this matter)
But later states:
implying Ie and Ic are the same. My original calculation added the 50 uA to the collector current. I'm not entirely certain if this is the case. It's not a large current but this is something we would account for with standard BJT with base current.
dl324
Joined Mar 30, 2015
18,491
For sufficiently high values of beta, Ib is small enough that ignoring it doesn't have a significant effect on calculations. It would have been better if the equations showed that Ie was approximately equal to Ic. But it's less than 1% error in this case.
Wolframore
Joined Jan 21, 2019
2,619
At active region with beta of 100 it's approx 1% but during saturation you can get higher error: the emitter and base current difference shows even in this simple simulation... I can't find one for a phototransistor... not even sure if you can model one which needs a light source.
38,920
Okay, but where is this base current coming from?
Re-read my post #14.
As I stated, you can't generate a current from nothing, so it must be part of the collector current if there is no external base connection (and most phototransistor have none).
What about that is difficult to understand?
Wolframore
Joined Jan 21, 2019
2,619
It’s not nothing. It’s like current generated by solar power. It’s created when the photons excite the electrons to jump the band gap.
Same concept as current from photovoltaic cells?
