PhotoTransistor with peak spectral sensitivity at 1550nm?
Islam Rostom
Joined Jan 31, 2016
6
Hello, First of all sorry if i posted this in the wrong forum if there is a more dedicated forum for this kinds of questions please tell me and i will delete this thread and post in the right forum.
Second i am working on a project which i need to detect light intensity with 1550 nm wavelength. Photo diodes are great and i am actually using one, but i really prefer phototransistors so if anyone know a phototransistor with those specs or a compnay that may supply this please tell me.
Thanks in advance
Papabravo
Joined Feb 24, 2006
22,115
That's almost twice the wavelength of red (700 nm) so you're pretty far into the infrared region. I can't find one either so maybe they don't exist.
Bordodynov
Joined May 20, 2015
3,431
I think you will not find such a nonstandard phototransistor. In conventional phototransistors, the base-collector transition serves as a photodiode. You can only look for a photodiode at the desired wavelength.
38,909
i do not see how would that help but anyway it is FGA01 from thor labs
Okay, I misspoke. :oops:
That's an InGaAs photodiode designed for long wavelength detection and their likely are no phototransistors very sensitive in that region.
Why do you want a phototransistor?
Are you having a problem with sensitivity?
DickCappels
Joined Aug 21, 2008
10,661
A paper describes describes a phototransistor as having "High responsivities of ~1.8 A/W at 1550 nm and ~0.043 A/W at 2003 nm were demonstrated with low dark current density of 0.147 A/cm2."
Edit:
This link (below) to the paper seems to work consistently. It should take you to a page with a captcha on it, if not Google the string in the quote above.
https://www.osapublishing.org/viewmedia.cfm?uri=oe-25-16-18502&seq=0
Maybe one on the authors of the paper can be of some help, particularly if you don't need many.
The partially successful search term was SWIR phototransistor
Papabravo
Joined Feb 24, 2006
22,115
The paper at the link below describes a phototransistor as having "High responsivities of ~1.8 A/W at
0.147 A/cm2."
https://www.osapublishing.org/captcha/?guid=90829AD8-CBC8-4DB1-4FDF-327B0B3AFD50
@DickCappels ..You have a broken link there.
