I am a beginner PSPICE, in simulation electrical and electronics circuits. I want to simulate a schematic with the program Micro-CAP 12. I want to look for some graphics from a photodiode PIN which is a InGaAs Photodiode IG22-Series, I want to monitor follow parameters:
And at the transistor BFP420 I want to monitor some graphics at the following parameters:
I do not know how to begin. Please help me. I accept, if is necessary any simulator of circuits.Or only important electrical parameters.
Thank you for understanding,
Dragos.
- responsivity (A/W) vs wavelength(nm);
- dark current (A) vs reverse voltage (V);
- shunt resistance vs. temperature;
- detectivity vs. shunt x area;
- capacitance vs. reverse voltage;
- responsivity temperature coefficient.
- total power dissipation Ptot = ƒ(TS);
- permissible pulse load RthJS = ƒ(tp);
- permissible pulse loadPtotmax/PtotDC = ƒ(tp);
- collector-base capacitance Ccb= ƒ(VCB)f = 1MHz;
- transition frequency fT= ƒ(IC) f = 2 GHz VCE = parameter in V;
- power gain Gma, Gms, |S21|² = ƒ (f) VCE = 2 V, IC = 20 mA;
- power gain Gma, Gms = ƒ (IC) VCE = 2V f = parameter in GHz;
- collector-base capacitance Ccb = f (VCB) VBE = 0, f = 1MHz;
- noise figure F = f (IC) VCE = 2 V, ZS = ZSopt;
- noise figure F = f (IC) VCE = 2 V, f = 1.8 GHz;
Dragos.
