PCB return currents at low frequency and High Frequency
hoyyoth
Joined Mar 21, 2020
531
Dear Team,
I am new to pcb design.I the PCB learning material I found that for
Low Frequency Return Currents Take Path of Least Resistance and High Frequency Return Currents Take Path of Least Inductance
--Could you please tell me why and how it is happening ,
Regards
HARI
38,856
All traces or wires have a small inductance.
The inductive reactance goes up with frequency.
At low frequencies this reactance it less than the trace resistance so the current follows the least resistive path.
When the frequency gets high enough that the trace inductive reactance exceeds the resistance than the current will follow the least inductive path.
hoyyoth
Joined Mar 21, 2020
531
Thank you.
In a PCB how will we identify least resistance path and least inductive path.
Let us take a two layer PCB with L1-Signal and L2 GND.
When the frequencies become high frequency
Deleted member 115935
Joined Dec 31, 1969
0
Thank you.
HI @hoyyoth
The easy answer is two fold
a) Its possible to do a full field 3D simulation that will give you within a few percent accuracy the numbers,
BUT , the tools are horrendous expensive, need a fair machine to run, and a fair skill set ( garbage in garbage out )
b) most of the time, you will learn by experience / your mentors as to when to worry
this might help
https://www.academyofemc.com/emc-design-guidelines
