Greetings all
I've a report regarding PCB manufacturing where i need to compare and contrast TH PCB to SMT PCB.
Assuming i need to create a 1 Layer Double side PCB, I understand for Through-Hole components the
board needs to be drilled and since it's a single layer board i can connect components on the top layer
easily with the bottom layer.
In the case of an SMT PCB, where the board doesn't need to be drilled and components can be mounted
on surface pads, how would smt components on the top layer connect to the bottom layer since SMT PCB's
don't need to be drilled?
