PCB Burning from Hot resistors
RodneyB
Joined Apr 28, 2012
698
I have attached a picture of a PCB that I have which is burning from the heat generated by the resistors. Is there any way of protecting the PCB from burning.
I was thinking about putting aluminium foil under the resistors but needed conformation and then that also comes with a set of its own problems.
#12
You can also buy resistors that don't run so hot per watt, or just buy over rated resistors like 5W rated in a 3W position. I recognize that particular shape as a resistor that can survive higher temperatures...but the circuit board can't!
#12
Yes. There are several ways to get bulkier resistors, some round, some square. What I wanted to emphasize is the ends being larger than the resistor body and that light grey background color indicating the, "run hot" resistors.
mcgyvr
Joined Oct 15, 2009
5,394
Resistors should always be sized at 2 to 3 times the required wattage and then keep them off the board by 1/8" or more.
That should be more than sufficient.
alfacliff
Joined Dec 13, 2013
2,458
if thbere are no pc runs under the resistors, drill some holes in the fiberglass for ventilation. also, if you have replacement resistors, mount them on longer leads to space them above the board.
sheldons
Joined Oct 26, 2011
613
All good advice but as the circuit is just powering leds there should never be that much heat generated resistor wise to burn the board in that way if the resistor value/wattage has been properly worked out with reference to the supply voltage available. ....are these ran direct from mains ? What is the mystery supply voltage used ??? You could fit slightly higher wattage resistors and space them away from the board a little.....
ErnieM
Joined Apr 24, 2011
8,415
If you look carefully at the picture the annular rings for the resistors also show discoloration. This is due to the leads themselves conducting heat out of the resistor into the board. Spacing the body of the part will only help a little with that issue.
The pads should be greatly increased in size to large copper masses to aid in heat dissipation. These pads should be of the "thermal via" type that isolated the pad a bit from the mass so you can still solder to it.
35,189
I think the issues are very obvious:
  1. PCB is charred
  2. Resistors not rated for proper power dissipation
  3. Solder joints will deteriorate
You are powering the LEDs from AC mains, correct?
That is a violation of the Terms of Service (TOS) of All About Circuits and further discussion along those lines will result in this thread being closed.
sheldons
Joined Oct 26, 2011
613
There's diodes there too(1N4007 ?)......still shouldn't be running hot as they are only driving leds....so....what is the supply voltage used???...
