Part needed, not sure what it is called "electronic switch?"
LowQCab
Joined Nov 6, 2012
5,102
Don't need luck, helped build one - just need to build it for myself so I can have atmospheric power instead of that"solar" crap
So exactly how much Power did You get out of the device that You helped to build ?
How much Power did You have to put IN to get that much Power ?
I'm guessing that so far You haven't been able to
get the Device to "resonate" properly,
and that's why you're here asking for advice.
Let me save You some time .........
Devices do exist that produce Electrical-Power by very unconventional means.
The Technology for producing those types of devices has not been publicly released yet.
You can't "accidentally" figure-out how these types of devices work.
Thousands of extremely smart people have been trying to figure this out for
hundreds, or even thousands of years.
Anytime someone actually gets close to figuring out how to do it, they disappear.
The US-Military is suppressing this info at this time, and for very good reasons.
It will be released when conditions are deemed appropriate.
But it probably won't be discovered and released by You,
especially when You are new enough to Electronics to
need to ask for help with designing a simple Self-Oscillating-Transformer
Look-up a "Hiemz-Transformer" and "Flyback Oscillator".
If You can combine these 2 designs,
and still get it to function,
You might have something interesting to play around with.
BobTPH
Joined Jun 5, 2013
11,645
Turn out, the patent is a free energy device that makes no mention if atmospheric electric fields.
From US patent application 6,362,717B1
1. Field of Invention
This invention relates to a magnetic generator used to produce electrical power without moving parts, and, more particularly, to such a device having a capability, when operating, of producing electrical power without an external application of input power through input coils
halchair
Joined Dec 26, 2022
11
So you expect to get useful power out of this?
I repeat, good luck. It has been studied since Ben Franklin and no useful power had been demonstrated yet.
The guy I helped build the first 3 systems with took off, powering his 100% electric boat with it. so ya, it makes lightning bolts on demand (so long as it is in an atmosphere).
Look into the energy spike you get with a collapsing magnetic field and how you have to put a diode in the circuit to keep it from shorting out stuff from the sudden power spike.
Making that happen on demand in a controllable way is what this does... it is just frequency, and collection coils.
halchair
Joined Dec 26, 2022
11
Oh that, he tested it with 24 volts, 1 amps in, and got (with proper winding) about 120 volts 1 amp out .
Timing is set to 60htz to "resonate" properly.
Next he scaled it up so he has 3 systems each cranking out 30,000 watts powered by 6000 watts going in.
2 of them produce 110, the third 220 (for his fricken ac).
NOTE: the device will melt if you do not regulate the power IN, do not just connect the output (collection coils) to the input coils or it WILL MELT THE DEVICE. (increasing your input by a factor of 5 over and over....that is why he ended with 3 systems instead of 4). Give it a fixed amount of power in and you are ok.
And yes, he "vanished" onto his own private yacht (a small one) - 100% electric, even the motor - with a crew of 4 smoking hot chicks... (I still have to figure out the hydroponic stuff he had set up, but that is a known tech I can learn later - and a MIT solar steam generator per person to make sea water drinkable 2 to 10 liters each day per unit - I already got that, just need to put it together).
The DEW's... heck I used those already for self defense, you can't out run a light beam (that introduces you to 3000 degrees) unless you can move and react at the speed of light.
So accidentally? no - I know what I am doing and why, I just need to understand some circuits.
There is no "appropriate time" for the government to release this tech...
There is ZERO benefit to keeping the world in a state of energy poverty... That causes war, famine, pestilence and death.
Truth is we got a bunch of children with the IQ of a dead stump wanting to be better then everyone else - these people are happy living in a drafty castle wiping their butt with a rag and having no electricity... So Long... As they decide who lives and who dies, total nut jobs.
If you think you can trust your government to think for you, maybe you should just tattoo "US government property" on your butt and ask them when you can breath.
Now as for me... I have friends in "high places" because I am a free man who thinks and acts of himself.
https://rumble.com/v1m2msm-ufo-video-2-from-day-one-of-them-parking-over-my-house.html
(they fried my camera when I brought it up... or I would have filmed a lot and not have to rely on memory for "future projects")
But don't you worry about me G. I am almost down to ordering the last few parts at this point, I just need a little help to get things worked out and I will be on my way good sir.
If you can learn by looking over my shoulder like I did looking over his, more power to you.
If you want to be a slave and let others tell you "what is good for you" instead of figuring out what is going on for your self - then stop talking to me...
You may start to think properly in a "how can I solve one little problem at a time until it works" vs "OMG ITS IMPOSSIBLE" before lighting your hair on fire and running around in a circle screaming...
Because the US army says its good for you to do that.... They know what is best : )
BobTPH
Joined Jun 5, 2013
11,645
I am quite certain I know more about the spike that comes from a collapsing magnetic field than you do. For one thing, it cannot have more energy than the energy put into creating the magnetic field. For another, you cannot capture all of the energy.
djsfantasi
Joined Apr 11, 2010
9,237
I am 100% sure that “the guy” didn’t do that and he is pulling your leg.
That would be against the law of physics! Power out must be less than power in due to losses in every circuit. Power in Watts can be defined as volts times amperage in an electrical circuit.
The power in is 24V x 1A or 24W. According to you, he achieved power out of 120W. According to all the math I know, 120 is not less than 24, hence this could not happen.
This doesn’t require mysterious technology nor US military secrets. Even they have to follow the laws of physics - unless he lived in a parallel universe.
