Hello there,
it is known that if we realize a filter (for instance a low pass filter) by using distributed elements (transmission lines), there will be some parasitic passbands (which moreover show a behaviour which seems "periodic").
For instance I did this simulation of a Butterworth filter of 5th order:
Note that it behaves as a perfect low pass filter only for few GHz after the cut-off frequency. What is the cause of this phenomenon?
