The connector that I am tapping into connects directly to the micro switches in the shifter.You said this in the first post. Why not take wires going to the manual part of the existing shifter and extend them to the paddle shifter?
It's not real common, but some do here and there for strange reasons. I had a Ford once that the cruise switches on the steering wheel were set up this way... cheap and easy I'd imagine was the motivation.I'm no automotive controls expert, but it seems odd to me that they would use analog voltage levels like that as control signals. We need someone from the automotive industry to chime in with some feedback.![]()
The way they have designed the paddle shifter, they are using (what I assume is) a current loop to transmit 3 unique states over 2 conductors. I am betting the reason for having only 2 conductors is because of limited room in the "coil" which electrically connects the rotating steering wheel to the stationary body.You said this in the first post. Why not take wires going to the manual part of the existing shifter and extend them to the paddle shifter?
Does the paddle shifter connect to the wheel? I don't have one but would bet it is just connected to the steering column like the turn signals are. Why would you want to 'chase' the paddles around with the wheel to shift? The ones I've seen in the car magazines seem to be column mounted.The shifter in the center console however is not limited in conductors by a rotating joint, and we see per his drawing in post #36, 5 wires are coming out of it. Therefore it is not guaranteed to be using the same sensing method as the paddle shifter, implementing a current loop over 2 conductors.
But let's say for a minute that the center console shifter sensing method was the exact same as the paddle shifters, 2 wire current loop. How would you suggest connecting the paddle shifters with the console shifter? In parallel? How do you connect 2 current loops in parallel? In series? I think things will "out of whack" immediately given the resistor values.
Ah ok I see. I did some more poking around, Took a trip to the dealership, and here’s what I came up with:Happy Holidays !
Allaboutautos put up a link, did you look at that ? I will put up 2 links, follow them at your own risk..
https://www.powertraincontrolsolutions.com/Vehicle_Manufacturers/Catalog/PCS_OE_CATALOG_915.pdf
https://www.ebay.com/itm/USB-Logic-...723690&hash=item2ca15245bc:g:4IgAAOSw4CFYtr~B
The scope shots that you posted are at 0.1 second resolution, CAN BUS supports up to 1 Mbit/s
The PCS Paddle Shifter provides upshift and downshift commands to a PCS transmission controller, a PCS GSM push button shifter, or a GM mechatronic transmission such as the 6L80. The paddle shifter is available for either 5/6-bolt or 9-bolt steering columns. The paddle shifter communicates wirelessly to a receiver module that interfaces the CAN network.
