Output power in dbm
Hadia35
Joined May 25, 2017
16
If an output of an ic is given 14dBm and it's gain is 13dB. So if an input of 12dBm is applied then what must be it's output ?
Papabravo
Joined Feb 24, 2006
22,116
It doesn't work that way. Using dBm means that you have a FIXED reference of 1 milliwatt. If the input was 12 dBm the device would probably be overloaded. The 14 dBm output is obtained with an input of 1 dBm. So 1 dBm plus a gain of 13 dB gets you 14 dBm. Got it?
bertus
Joined Apr 5, 2008
23,031
When you want to drive an amplifier capable of 14 dBm output and a gain of 13 dB with 12 dBm input, you will likely blowup the amplifier.
If it not gets blowup, a lot of unwanted signal will be present on the output due to the non linearity of the amplifier.
Bertus
Hadia35
Joined May 25, 2017
16
Okay thank you.
Papabravo
Joined Feb 24, 2006
22,116
Bertus
A bit dramatic perhaps. Many amplifiers have overload protection, but your point is well taken
Hadia35
Joined May 25, 2017
16
I am using hmc462lp5 which is an lna . In its data sheet the output power is given 14.5 dBm, 13dB gain and absolute maximum rating of input power which is 18dBm. With these values won't the ic get overloaded ?
bertus
Joined Apr 5, 2008
23,031
Did you see the specs table?
With 12 dBm input and 13 dB gain you will get vey close to the IP3 point and go over the saturation point.
Bertus
