input power pin not driven by any output power pins vcom kicad
chandimajaya85
Joined Sep 27, 2023
41
I am getting error message on the KiCad. Not sure what to make sense of this error. Attached the picture. Screenshot 2025-12-12 064751.jpg
I tried attaching PWR_FLag but then I get a different error message shown below,
28,279
The problem is that the symbol used defines it as an external power input, while it is the device output.
The fault is an incorrect symbol, the only solution is to use a different symbol.
When working with a simulator you must only speak it's language.
panic mode
Joined Oct 10, 2011
5,250
the problem is that you are using wrong symbol for "VCOM". do not use any of the "power" symbols:
here is an example of using global label.
panic mode
Joined Oct 10, 2011
5,250
btw. if you do insist on using power symbol there, you would have to add some component between the power symbol and the output, something like zero ohm resistor or jumper...
